Question about Mobo Three-Wheel Cruiser Tricycle
How to install a new sprocket on a 3 wheeled tricycle
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
I need the assembly manual for the 24 inch -6 speed 3 wheel tricycle I purchased. THe manual that came with tricycle is of poor quality and does'nt show detail for postitioning of nuts and screws.
Look on your manual if you have the website of distribuitor or maker, and check if site has some kind of contact or Consumer Sevice link
May 14, 2015 | Computers & Internet
How do I change the drive belet
To remove a 2007 Touring drive belt FIRST remove the rear wheel and the rear swingarm, remove the primary chaincase assembly,remove the old belt from the transmission sprocket.
To install a 2007 touring drive belt FIRST install the new belt on the transmission sprocket, then install the primary chaincase assembly, then install the rear swingarm and the rear wheel and adjust the belt deflection to specifications.
Belt Deflection
Vehicle Orientation Model Inches Millimeters
Motorcycle Upright
With Rear Wheel in Air
or On Jiffy Stand
Without Rider or Luggage
FLHR/C,
FLHT/C/U, 3/8-7/16 9.5-11.1
FLTR
FLHRS,
FLHX1/4-5/16 6.4-7.9
Apr 27, 2014 | 2007 Harley Davidson FLHRC Road King...
Why are the rear wheels locked up on my toddlers schwinn tricycle?
I took the fenders off to give a little more space for the wheels to move. Don't tighten the nut and washer right up against the black plastic spacer on the rim. Schwinn should be sending out locking spacers or nuts to fix the problem, but I don't see that happening.
Sep 23, 2012 | Pacific Cycle s Schwinn Roadster 12"...
How to put a tire back on the axle of a goped grt46 and with spacers and washers
Simple, go to goped.com and find the Video section of the website there you will find a link to videos that will help.
1 put axle through frame
2 spacer and possibly a washer or two on the axle. Then wheel but make sure the sprocket on the wheel is lined up with the sprocket on the motor as you may need to add or take away a washer to get the alignment just right.
3 install wheel and put chain on the sprocket. Note, you may need to move the axle out of the way to get the chain on the sprocket and then wheel on the axle.
4 install spacer for the fender.
5 install fender
6 install and tighten axle.
Done
Mar 12, 2011 | Go Ped Toys
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
May 10, 2009 | Razor MX500 Dirt Rocket
Mobo Three-Wheel Cruiser Tricycle Logo
Top Mobo Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Mobo Cycling Expert? Answer questions, earn points and help others
