Washer will not fill with water
Model 110.159642
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Check the door luck
Posted on Feb 10, 2014
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Errpr code 4e on samsun aqua jet vrt
A 4E code on Samsung washers means that the washer isn't filling properly or the sensor isn't detecting the water flow. First, make sure that the water shut-off valves are open. Next make sure that the drain hose outlet is positioned above the fill level of the washer. (This avoids the water being suctioned out of the tub.)
Turn off the shut-off valves and disconnect the fill hoses from the washer and the valves. Clean the filters in the washer and at the valves. Reconnect the hoses to the valve and place a bucket under the other end. Open the valves and check that you have good water flow from both hoses. You may want to replace the hoses. (Some washer fill hoses are designed to clamp shut if they detect a leak. This anti-burst feature will reduce the water flow to a trickle. Since the washer fill sensor detects the amount of water in the tub within 8 minutes, that will trip the error.)
If the washer isn't filling and there is plenty of water coming from the water line, the fill valve probably failed in the closed position. If the water level is rising, then the sensor is probably faulty.
Please add a comment with the full model number of your washer. Then I may be able to point you to the parts. If the washer is under warranty, contact Samsung.
I hope this helps.
May 01, 2015 | Washing Machines
Water not filling up kenmore washer model number11024642300
The most common thing that causes the washer not to fill up with water is the water inlet valve. If this valve has power to it when it's supposed to be filling with water, and you have adequate water supply to the washer, then the washer should be filling with water. The part number for the replacement valve is 285805.
Mar 22, 2012 | Kenmore Washing Machines
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not fill with cold water during cycle
it sounds like your mixture valve is faulty on the cold water side. that is the valve where you screw the hose ends on. it needs to be replaced you can purchase one at your local sears, be sure to take your make and model number with you
Dec 31, 2008 | Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
