Question about Sharp UP-700 Cash Register
Lost clerk key need to reset
I have a second hand machine but clerk key 10 is missing with an unfinished transaction so I cannot do x or z reads. I have a service key
This register appears to be ''closed''. Every mode states to be closed
closed means there is no clerk signed in. if either pressing the clerk button at the top right of keyboard or pressing 1 clerk does not sign in a clerk it has probably lost it's programming. to reset to factory condition turn the C key to six oclock position and unplug then reconnect plug while holding down the double zero button
Jan 03, 2014 | Sam4s SAM5215 Er-5215M 1
How can I reset OIL MAINTENANCE REQUIRE RESET UNFINISH message on Toyota Landcruiser 2010 diesel?
The sequence should be: Depress and hold the mileage reset button on the gauge cluster. While holding it in, turn the ignition key to the run position ( do not start the engine), You will see the mileage read "0000000" for 5 seconds, and then see the mileage return. After the mileage returns, the "Oil Life" has been reset. If you have the owners manual, it will be inside. Good luck.
Dec 07, 2013 | Cars & Trucks
How can I reset (oil reset unfinish ) message on Land Cruiser2010?
Land Cruiser
Reset the system by the following procedure:
1. Turn the ignition key to the "OFF" position with the odometer reading shown.
2. Turn the ignition key to the "ON" position while holding down the "ODO/TRIP" knob.
Hold down the knob until the light goes off. Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds, illuminates for 1 second.
Nov 03, 2013 | Toyota Land Cruiser Cars & Trucks
Clerk key #
Are you sure it has been setup to use clerks by code number? This model can also use the buttons next to the key for clerk logon. If you have the USA version, the clerk buttons will not be there and you must log on with a clerk code. The default for each clerk is the same as the clerk number, so try 1 CLK#, 2 CLK# etc and see if you can log on. Otherwise, you will need to read the programming with an owner key to find out the clerk codes. See how you get on
Apr 17, 2012 | Casio Parts Cash Register PC Desktop
Hi, I have a Casio TE-4500F and am having problems configuring the clerk interrupt function. If I Iog into the register using one clerk number say 1 - CLK#, as soon as I have pressed a PLU key to start a...
Are you new balancing before you try to log the second clerk on? Make sure you don't have the check tracking selected. You can use interrupt or tables, but not both.
If anyone is looking for a Casio TE-3000, 4000F, or 4500F manual, c-tech can help
TE-3000S operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_users_manual.html
TE-4000F, 4500F operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-4000F_and_TE-4500F_users_manual.html
TE-3000S, 4000F, 4500F programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Oct 19, 2010 | Casio Parts Cash Register PC Desktop
I have a casio ce 3700 and I can't log on. or anything. we got it second hand today. there is no user manual or anything. We basically just need it to open and close to lock up the cash. and as an adding...
this should be easy enough. You will most likely need to use the reset button on the inside of the printer cabinet. Once reset you may need a new battery .
Unplug the machine. Turn the key to program. HOld down the red reset button inside the printer cabinet. After counting to 10 release the reset button. If the display comes back with all "'0's" all should be good. If this gets this far then enter 12001 and press subtotal. the machine will stall momentarily and be ready to run.
Dec 17, 2009 | Casio Parts Cash Register PC Desktop
Casio CE-3700 lockup
It sounds like you have a flat, or faulty backup battery. The machine has probably lost all programming. This is common if the machine has been stored.
Try this:
Turn key to program.
Turn power off at wall.
Hold JOURNAL FEED.
Turn power on at wall.
When you see '000000000' or 'LLLLLLLLLL' type 21151 (for Europe), or type 12300 (for USA) then press SUBTOTAL
If you still have trouble, just let me know.
Mark
Aug 18, 2008 | Casio Parts Cash Register PC Desktop
Sharp UP-700 Cash Register Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
