Question about Haier (HBF05EAVS) Beverage Dispenser
HAIER BEER REFRIDGERATOR
MY BEER DISPENSOR IS 2 YEARS OLD THE TEMP IN THE BOX NEVER GOT BELOW 41 DEGREES,I THINK THIS COULD BE THE T-STAT,CAN I MAKE AN AJUSTMENT TO THIS STAT OR GET A NEW ONE.THANK YOU
I have this same problem.  I have read discussions on this exact topic in several forums, and I have come across a link to a Haier Service Website.  http://service.haieramerica.com/  When you go to this site login with password "HAIER" and UserID "HAIER" and look up your model number (my model number is "HBF05EABB)".  There is a "service bulletin" which provides instruction/pictures for adjusting the thermostat.  I have not tried this yet, but I intend to later tonight.  I like my beer a little cooler than 41 degrees!  Hope this helps.
Posted on Oct 30, 2007
The Haier website worked like a charm, with easy instructions and pics, there is a specific service bulletin for this problem....thank you
Posted on Sep 21, 2008
  • Haier Master
  • 4,655 Answers
You can possibly get the temp down a little more if the door seals are good and room ambient temperatures are not high. If the condenser fan or coil are dirty cleaning them will help too.
I the door is opened a lot will keep the machine going trying to lower the temps. so if the beer is in a high turnover situation it may help to pre cool the beer before sending it to the Haier cooler.These are all possibilities and can be answered by going over some solutions listed. 41 degrees may be the lowest setting for that cooler and will need to have further research on the thermostat to answer that. If it is a simple t-stat it can be replaced easily, Thanks Sea Breeze
Posted on Oct 27, 2007
We set it at a temreture of 70 degrees but it wont go of when it gets really warm in my house does that mean that the termostat is old or what ????
Does the temp on the thermostat ever get to 70? As long as its at least 2 degrees below it will keep running, until it gets to the value you set. To test place a thermometer on top of the stat and compare the temp to its readout, if its still accurate it should be within 2 degrees of the reading. Keep in mind the location of the stat affects it (away from drafts, etc.) as well as making sure its vent holes are clean and clear, has good batteries and the area around it has nice unobstructed air flow.
Mar 08, 2015 | Emerson 1F80-0261 Blue 2" Thermostat,...
I have a 2004 grand prix gt my coolant temperature gauge goes up when um park but when I drive it goes back to normal.its not running hot I change thermostat both fans work I think its the water pump r the...
First off when did this start? Was it prior to the Thermostat replacement or after? What was the purpose of relacing the tstat?
From my experience use only a high quality t-stat that maintains a constant temp. is the best solution, it's easy to try and save a few bucks I'm just as guilty as the next guy however I've had many years of experience in the automotive field, throughout the years I've replaced hundreds if not thousands of t-stats and all are not even close to created equal. My opinion is not to go to the big box stores to purchase an off branded t-stat these t-stats open very inconsistantly and tend to have temps that fluctuate greatly. Commonly these economy t-stats are rated at say 195 degrees however they tend to snap open and closed very fast and erratically causing the temp to suddenly drop and then snap closed when the coolant falls below the opening temp. And again reopen not at the 195 always but sometime not opening until say 205 or 210 and then again snaping open and the cycle continues. Buy a premium t-stat and you'll be glad you did.
Dec 30, 2011 | 2004 Pontiac Grand Prix
I have a Danby Kegerator I purchased at Sams Club a couple years ago. The temperature readout said LE at one point and now it will cool down when I first plug it in, but then it warms up to between 50-70...
contact mark pasieka for a repair.... mail in the board and he can fix it and send it back.... if you live in the chicagoland area he is a liscensed for all types of refridgeration, and since he has 2 degrees in electrical engineering he is especially proficient when the issue is electrical in nature...
mark.pasieka@gmail.com
Sep 21, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a Sanyo kegerator that will not cool enough. I have set the thermostat as cold as it will go and it will only go down to about 42 degrees. What can I look for?
Drop thae stat it's a screw on the left side that controls temp.Don't rush this you don't wnt to freeze your beer. 1,5 turns to the left will take you down to ice cold beer.
Nov 18, 2008 | Sanyo Refrigerators
Beer not getting cold
Try cleaning the coolers condenser core.
Jul 06, 2017 | Frigidaire PLKU1267DS Stainless Steel...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 07, 2008 | Haier BC112G Wine Cooler
Humidifier not taking out water
I have the same problem. I have had the unit less than a month. Haier's policy is for me to pay $14.99 so they can send me another one. What a huge ripoff.
Jun 03, 2008 | Haier 65-Pint Dehumidifier
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
Haier (HBF05EAVS) Beverage Dispenser Logo
789 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
