Question about Omega BMJ330 Mega Mouth Juicer
My Omega BMJ330 big mouth juicer wont start
Is plug on the electrical outlet but do not start when switch on
  • Mark Mar 02, 2017
    I have the same problem. Did you figure it out??
Where do we get replacement part cover for Big Boss Juicer ? in Canada
Try calling 1-800-423-4248 ext 233, or here is the Contact Us page for Emson, the distributor of Big Boss products: Contact
May 10, 2016 | Big Boss 700-Watt, 18,000 RPM Juicer,...
After plugging it into a Indian socket my entire house electricity tripped
Could be the appliance is faulty or is intended for a different mains voltage. If your mains are 220/230 volts and the appliance is intended for use on 110 volt mains...
Sometimes appliances are intended for universal use and must be adjusted before use. The instruction book will give details.
Sometimes an appliance is supplied with an unsuitable power plug and sometimes without a plug at all, requiring the power plug to be changed for a suitable type. This process is or has been responsible for many minor disasters and a few major ones. It is important such a basic and routine thing is performed competently.
It is of course possible something was or is wrong with the power outlet or perhaps the atmosphere was steamy and some condensation was carried into the outlet when the appliance was plugged in.
I hope this helps.
Apr 26, 2016 | KitchenAid Kitchen Aid KFP715OB - Food...
My arm broke on the the plastic and can not be fixed what do I do now ?
If it cannot be fixed, then you'll want to be looking at a new juicer.
If you're not sure if it can be fixed or not (as this is a common problem with some juicers and is quite fixable) then you'll want to contact the manufacturer and have them send you the appropriate replacement parts. Contact Omega at 800-633-3401
Omega Products website - http://www.omegajuicers.com/contact-omega-juicers/
Mar 21, 2015 | Omega Centrifugal 1000 Juicer
How do I unlock my Juicer. It became locked while using it.
When you say it became locked do you mean the motor locked down and it won't spin or do anything ?
Feb 03, 2015 | Breville Juice Fountain Compact Electric...
Food processor won't turn off
Probably going to require a new 3 button switch panel, they are not hard to fit.
Feb 17, 2013 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Owners manual for oster 2 speed blender model 4125
2 3
IMPORTANT SAFEGUARDS
When using electrical appliances, basic safety precautions should be followed,
including the following:
READ ALL INSTRUCTIONS BEFORE USE
• Unplug cord from outlet when not in use or before cleaning.
• To protect against risk of electrical shock, do not immerse the cord,
plug or motor base in water other liquids.
• Do not let cord hang over edge of table or counter or touch hot surfaces.
• Never leave appliance unattended when in use.
• Close supervision is necessary when used near children.
• Avoid contact with moving parts. Keep hands and utensils out of jar
while blending to prevent personal injury or damage to the blender.
A rubber spatula may be used only when the blender is not running.
• The blade is sharp. Handle with care.
• Always put the lid on the jar before operating the blender.
• Do not operate any appliance with a damaged cord or plug or after
the appliance malfunctions or is dropped or damaged in any manner.
Return the appliance to the nearest Authorized Sunbeam Appliance Service
center for examination, repair or electrical or mechanical adjustment.
• Do not use outdoors or for commercial purposes; this appliance is for
household use only.
• Use this appliance for its intended use as described in this manual.
• When blending hot liquids, remove center piece of two-piece cover.
• To reduce the risk of injury, never place cutter-assembly blades on base
without jar properly attached.
• Always operate on a flat surface.
• Unplug the blender when it is not in use, before taking off or putting
on parts and before cleaning.
• The use of attachments, not made by manufacturer, including canning
or ordinary jar and processing assembly parts, is not recommended
by Sunbeam Products, Inc. and may cause risk of injury to persons.
THIS PRODUCT IS FOR HOUSEHOLD USE ONLY
The maximum rating marked on the product is based on the attachment
that draws the greatest load. Other attachments may draw less power.
P
OWER CORD INSTRUCTIONS
Please follow the instructions below to ensure the safe use of the power cord.
• This appliance is equipped with a polarized plug. This type of plug has one
blade that is wider than the other. This plug will fit in a polarized outlet only
one way. This is a safety feature intended to help reduce the risk of electrical
shock. If you are unable to insert the plug into the outlet, contact a qualified
electrician to replace the obsolete outlet. Do not attempt to defeat the safety
purpose of the polarized plug by modifying the plug in any way.
• You may use an extension cord, if necessary, but be certain to follow
these guidelines:
- The marked electrical rating of the extension cord must be at least
120/127 Volt, 60 Hz, 10A.
- The extension must be arranged so that it will not drape over the
countertop or tabletop, will not be within the reach of children
and will not be tripped over.
• Do not pull, twist, or otherwise abuse the power cord.
SAVE THESE INSTRUCTIONS
Sep 03, 2012 | Oster Blenders
I was blending a slightly thick batter and the Vitamix just stopped! Will the machine start after awhile? Do you think it has just overheated? How do I find out ? My old Vitamix had a reset button at the...
Well it might just be over heated, let it cool for approx 20 minutes then restart if it doesn't then u may try switching electrical outlets, if that doesn't work then it needs to be replaced. I hope that this helps, if not please let me know and i will try and help you out as much as i can.
May 28, 2011 | Vitamix Super 5000 Work Top Blender
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Omega BMJ330 Mega Mouth Juicer Logo
265 people viewed this question
Top Omega Blenders Experts
rhodesworks
Lesley Cameron
Lesley Cameron
Glenn
Glenn
Are you an Omega Blender Expert? Answer questions, earn points and help others
