Question about Refrigerators
Admiral refrigerator ltf2112ar side ice - Refrigerators
  • 159 Answers
SOURCE: Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Posted on Aug 10, 2007
fridgetech
  • 473 Answers
SOURCE: Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator admiral
Frost on the low side line means the system is overcharged (too much freon).  Look on the tag insided the fridge and it will tell you how much freon it holds.  Usually 4.25-5.50 ounces on average.  The loud noise sounds like you have air in the system.  I would evacuate, from the high side while running, and let it run empty for 5-10 minutes.  Then while running put the valve core back in the high side.  Then unplug the fridge and charge with proper amount of freon thru the high side.  Wait about 5-10 minutes and plug back in.  Normal low side pressure should be 0-3 psi.  This is a good indicator of the proper amount of freon in a good working system.
Posted on Oct 14, 2007
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Maytag Admiral LTF2112AR Fan inside of Freezer not
That will not be hard to diagnose or repair. Unplug refrigerator in not already. Then remove the rear panel in back of the freezer. Unplug the wires to fan and check voltage to the wires that were taken off the fan for 120 volts while someone plugs the power back in. If you have voltage in the 2 wires then see if maybe someone closed the refrigerator for a while and let rust set in on the fan bearings. Try spinning the fan before replacing. It could be stuck from setting up. If the fan is burned out replace the fan motor part number 63001057 Plug back in and you should be good to go. Sea Breeze
Posted on Nov 21, 2009
Adjust water flow admiral ltf2112ar ice maker
Pull the cover off there should be an adjustment there
Feb 12, 2015 | Admiral Washing Machines
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
Water is dripping down the back of the inside of the refrigerator. Maytag Admiral LTF2112AR
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 15, 2011 | Maytag Refrigerators
Ice maker stoped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side refrigerator ,model sal2027gbb
icemaker water valve is bad check to see if you can tell if the unit is turning
Apr 16, 2009 | Admiral 26 cu. ft. Side-By-Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
My refegiator wont stay cold ,but my freezer gets cold my cooler grill gets like over iced and blocks the coolair from entering my refegiator .what to do. signed the admiral
Hi, for the meantime the admiral repair man not yet arrive you just defrost so that the ice will melted the cooling fan was shut off due to ice build up.
Jan 22, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
