Question about McCulloch Garden
Mcculloch mac 1010 oiler isent pumping
Oiler
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
mcculloch mac 1010 oiler isent pumping - helpful-rwwceix4simen0bu2pand4lt-2-0.png
Posted on Feb 22, 2018
SOURCE: Chain oiler inop
this is a common problem and requires replacement of the pump. remove the bar and chain, the pump comes loose with a few screws. under it you'll see the filter which could be clogged, but not usually as contaminants are not likely to enter the tank. Small engine shops can order the new pump for you, hope this helps
Posted on Jan 02, 2009
dontbother10
  • 2220 Answers
SOURCE: automatic oiler does not work
I wasn't able to find your IPL with what you provided. Somewhere (probably bottom) should be a black and yellow tag with the serial and model numbers. The model number on that tag is the key to your IPL. If you get that far and hit a dead end with parts repost with the correct model number and your best guess at what is defective. I've had great luck finding Mac parts for my saws.
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
HTH
Lou
Posted on Oct 19, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch 3516, The oiler isnt pumping.
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It sounds as though you have done most of 1. Continue with 2. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Please see the IPL to aid in oiler component identification. Good luck with your project
You can reply below with any questions. I hope you found this most helpful.
Lou
Posted on Jan 31, 2010
dontbother10
  • 2220 Answers
SOURCE: McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
  • 4088 Answers
SOURCE: what is the gas to oil mix for the Mcculloch mac
40:1 should work well. Be sure to use a modern synthetic saw oil and fresh fuel--mix in it's own can. Be sure to shake the can thoroughly just before filling the saw each time. Good luck!
Posted on Aug 11, 2010
Mcculloch Chainsaw Manual
Manuals may be downloaded using the links provided.
Contact us
User manuals
McCulloch Service
May 01, 2013 | McCulloch Mini Mac 6, Power Mac 6 Chainsaw...
My chain oiler is not working on my MAC 335
Sounds like something is clogged. I recommend contacting your local service center for assistance.
Contact us
User manuals
McCulloch Service
Jan 02, 2013 | McCulloch Garden
Mcculloch Mini Mac 30 Oiler does not work. cant figure out if it is the Oiler or the manual pump to feed the oiler
Contact us
User manuals
McCulloch Service
Dec 11, 2012 | McCulloch 1975 Mini Mac 30 Chain Saw Sales...
Mac 3816 chain oiler doesn't work
Contact us
User manuals
McCulloch Service
Nov 21, 2012 | McCulloch Fuel Gas Tank 3816 Maccat 18 16...
How to adjust oiler on pro mac 610
Unless indicated in the service manual, there is no adjustment.
Contact us
User manuals
McCulloch Service
Oct 12, 2012 | McCulloch Oiler 219991 Pro Mac 605 610 650...
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Chain not getting oil
Extremely difficult! If the oil pump or worm gear is defective it may be the most difficult saw to repair. This is the only saw I have seen with the oiler mounted behind the fly wheel.
McCulloch IPLs
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You can reply below with any questions. I hope you found this most helpful. Good Luck
Lou
If you opt to remove the fly wheel PLEASE reply to me first. I can probably save you a couple of headaches and may prevent component breakage.
Feb 01, 2010 | McCulloch Garden
I have a McCulloch 3516, The oiler isnt pumping. The screen is clean and free of dirt in the resevoir but the saw isnt pumping out any oil?/ How can I toubleshoot/ fix this problem?
McCulloch IPLs
Oil System Plugged.
Lou
Jan 30, 2010 | McCulloch Garden
Automatic oiler does not work , mcculloch em300s (electric), automatic oiler must be clogged? is there a pickup tube that can be blown out? need parts diagram to figure out if there is a pump inside.
McCulloch IPLs
HTH
Lou
Oct 18, 2009 | McCulloch Garden
McCulloch Mac 120 oiler
I think the problem is the funny rubber-hose-connection of the oil tank to the oil pump. It looks quite flimsy to me... But if you want I can have a look how this screw is adjusted...Bye, also tom
Jun 18, 2009 | Standard Oregon Chainsaw Chain For...
Garden Logo
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
