Question about Maytag Dishwasher
Clean light blink, dishwasher not working - Maytag Dishwasher
    Scholar:
  • 111 Answers
Does it blink 7 times pause then repeat if so then have a heating problem control does not detect a temperature rise, don't know your technical expertise I ohm out heater at the control easier than pulling out the machine just look for continuity means heater is good if none you'll have to reach under unit to make sure you do not have a burned wire to heater if heater is good ohm out thermistor at room temp should be between 50-70 thousand ohms very seldom does this part go bad but i had one so check it last if both parts check good then the electronic control is not outputting 120VAC to the heater.
Posted on Feb 09, 2014
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
It want come on the clean light blinks
its showing an error code check under unit there should be a tech sheet under there to remove error code
Jun 06, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Dishwasher clean light blinks
This is due to a problem with heating of the water. I have put together some instructions on what to do and how to reset the control so you can use the dishwasher. Follow the link below and let me know if it works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 07, 2010 | Kenmore Dishwashers
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems...
press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Jun 15, 2009 | Dishwashers
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Maytag Dishwasher Logo
43 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
