Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Freeunlockcode-motorizrz3 phone i gotaconsummer dual sim card
How do you know what slot to put sim card in slot 1 or slot 2
You either have a dual SIM card phone (it can use two SIMs with two different phone numbers) or you're confusing the MicroSD memory card slot with the SIM card slot.
If you truly have a dual SIM card phone, just put the SIM card in slot 1. Your phone's user manual should be able to offer further info.
May 19, 2017 | Cell Phones
A dual sim cell phone malfunction
HAve you ever experienced both working, most dual sim phone its one sim working at a time, you need to switch between the sims, via a switch on the side or via the menu,
I need the name and model for the phone
your vote counts for me
Mar 27, 2010 | Dual Electronics N99i Cellular Phone
Ive inserted a vodafone sim card in sciphone, phone sayn insert sim. also why is there 2 sim card slots?
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
Dec 16, 2009 | Lands Phones
What kind of sim card can be use for Qtek s200?
Qtek S200 is compatible with the dual SIM card Gold 1, dual SIM card Silver 1, dual SIM card Black 1.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Cell Phones
Second SIM not working
Settings>Dual SIM settings>Select "Dual SIM open>click OK
Jun 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
NOT READING SIM
If your phone has a dual sim card then the sim 1 card is the top slot and the bottom is the sim2
slot. Give it a try
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
How do you set it up for at&t
You shouldnt have to do anything to have it call. Do you have you sim card insered correctly? do you have dual sim card option and if so make sure your card is not in slot tw and you are using sim 1 option. On the dual sim card phones SIM 2 is placed upside down against the circuit board, and SIM 1 slot is facing correctly chip is on down side, and slightly elevated off the circuit. on your front display you should see AT&T and the SIM card location it is in. You do however have to set it up to receive picture text and internet acess. I can hep you with that also
Apr 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Chang Jiang A968 Quad-band Dual SIM Mobile Phone With TV
have teh phone replaced or try manually setting the network
Dec 28, 2008 | Cell Phones
How do I open the battery compartment on the motorizrz3?
Try: http://www.tecmediaplus.com/epages/tecmediaplus_com.sf/en_GB/?ViewObjectID=7993443
Dec 25, 2008 | Dual Electronics CECT P168 Cellular Phone
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
