TV went to black and white when hooking up the wii
You probably don't have something hooked up right or connected all the
way. If you are using component video cables, make sure that all of the
different plugs are plugged into the matching socket on your TV. Also,
make sure you have your TV on the right channel (3 or 4) if that's how
you have it setup.
Otherwise, you will want to look at the input settings on your TV and
make sure you are receiving the correct input, and if you have your Wii
plugged into a VCR instead of directly to your TV, try hooking it up
directly to see if it works.
If that doesn't work, try using a different TV - especially if it's a
TV you know works in color with a Wii. If it is still in black and
white, you might need to take it back to the store and exchange it for
a new one.
