Question about Destroyit 2604CC Shredder
Door sensor light will no turn off - Destroyit 2604CC Shredder
Why is door sensor not registering?
Hi , to test door magnet put close a small piece of iron, it should be attracted, this sensor is very rare to fail, possible the door sensor is faulty, this is a magnetic switch, to test it, you can put together both wires going to it (doing a short circuit to sensor), if the cable is OK the indicator of an open door should turn off and system will go to ready state. If all this happens, you need to change door sensor.
Nov 19, 2015 | Home Security
How do I clean the door light sensors. Where are they? My door lights won't go off.
I'm showing standard door jamb switches on each door, so there should be one on each door post or where the hinges are.
Keep in mind the dimmer switch for the dash lights could be turned on.
Jul 07, 2013 | 1994 Mercury Grand Marquis
Light turns on randomly
door latch has a sensor in it. possible one of the sensors is bad. door panel must be removed for inspection. disconnect each sensor until you find which one is causeing your problem.
Apr 22, 2013 | 2000 Mercury Sable
Garage door goes down and few inches and comes back up
Usually this means that your sensors on either side of the door are out of alignment or there is something blocking the sensors from making a connection. I did have a problem once were the door track twisted a little when the door started coming down thus making one sensor turn away a little and not allowing both sensors to make connection. Check to ensure the sensors are communicating correctly. Usually there are two lights, one on each sensor. They usually are red until they are properly lined up then they turn green. Some manufacturers have them flash until they are lined up then they stay on steady.
May 02, 2011 | General Electric GE 13-438 Overhead Garage...
DOOR CLOSES MOST OF THE WAY AND THEN OPENS. LIGHT THEN BLINKS TEN TIMES. I NOTICED THAT ONE SAFETY SENSOR IS GREEN AND ONE IS YELLOW. PLEASE ADVISE.
Hi. The sensor with the yellow light is telling you that it is miss-aligned, Usually it only takes getting bumped to knock them out of alignment.
I would slowly turn or adjust the positioning of the sensor.
The one with the yellow light should turn green when it is all the way in line so that the beam is completing it's path.
It's out of adjustment, so the sensor is looking at it like there is an object blocking the door from closing.
It's called the obstruction sensor.
It's there as a safety feature, so that the door doesn't come down and smash anything in the opening.
I hope this helps you out.
Feb 04, 2011 | liftmaster Garage Door 1/2 Hp
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
2000 GMC Safari, If the dome light is left on it is supposed to turn off after a time. It doesn't. How to fix?
This could be due to a door closed sensor broke and needs replacing Check all Door closed sensors and make sure none of them are defective
As if door is open light will remain on, If sensor has not noticed door is closed then light will not be triggered to turn off after a set time interval normally 1 min
Jun 21, 2010 | 2000 GMC Safari
How you turn off warning light door open light
there is a bad door sensor on one of your doors or the rear hatch. This is a tedious process go to each door with the other doors closed and unplug sensor till light goes off.
Mar 11, 2010 | 1999 Ford Expedition
For 1/2 HP belt drive opener: With the belt off, the motor sprocket only turns 1/8 - 1/4 turn each time the door opener button is pressed. Although nothing is obstructing the door or the sensors, the...
If the main light blinks 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. Tweak them a bit if necessary.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Destroyit 2604CC Shredder Logo
Top Destroyit Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
