Question about Toshiba E-Studio 2040c Copier
Total counter not function - Toshiba E-Studio 2040c Copier
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi I had a question about this. I get into test mode d on a Toshiba 2540 c and nothing happens. The screen remains blank only showing test mode d. Here is a screen shot of it. Can you let me know what I'm doing wrong?
http://screencast.com/t/vs4GK1NZk
Posted on Feb 23, 2016
    Problem Solver:
  • 11 Answers
Try in test mode d 203 in to 1 to 0
Posted on Feb 21, 2014
Sc 901 ricoh 2018d
901 B Mechanical total counter
The mechanical total counter does not
work properly.
• Mechanical total counter defective
• BICU defective
• Disconnected mechanical total counter
Apr 07, 2014 | Ricoh Aficio 2018D All-In-One Laser...
How to reset total counter of gestetner copier mp1500
You do not have any function that allows you to make a total couter reset.
Are you a technition? Why do you want to do that?
That is sheating! I will not tell you how to sheat.
Sorry!
Jul 14, 2011 | Gestetner Copier
How do I find the copy counter function on the E-Studio 600 copier?
If the e-Studio 600 is similar to other Toshiba models (like the e-Studio 452 or e-Studio 3510c) you can view the copy count by simply pressing the User Functions button, and it should be displayed in the lower right corner.
If you don't see it there, select Total Counter while you're in the User Functions screen, then select Print Counter.
Did that help?
Jun 06, 2011 | Toshiba COPIERS E-STUDIO 600 Copier
Dp-3030 E05-42 code ? help me ...... thanks
mainboar fuse outbreak
Thank you to everyone interested in
May 30, 2011 | Panasonic Workio DP-3030 Printer
How do you get into service mode on canon MF6560 (image class) ? Thanks RD
Press “Additional Functions”, “2", “8", “Additional Functions” in succesion.
Display will show “#SSSW”.
Press “+” or “-“ key repeatedly to go through the following menu list:
#SSW, #MENU, #NUMERIC, #SPECIAL, #NCU, #FAX, #SCAN, #PRINT, #NETWORK, #CODEC, #SYSTEM, #ACC, #COUNTER, #REPORT, #DOWNLOAD, #CLEAR, #ROM, #TEST MODE
Don't make adjustments in these modes unless you know what you are doing; could mess things up. Counter mode is especially helpful though for observing the performance (totals, mode, feed, and jam counts).
Jan 11, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Myprint totals say zero.
Press the counter check button. What counters do you see. There can be up to 6 different ones I believe. What counter numbers do you see e.g. 101: Total 1
Counters to display can be set using Service Mode. Press Additional Functions > 2,8 > Additional Functions.
Copier > Option > User > COUNTER1,COUNTER2,COUNTER3,COUNTER4,COUNTER5,COUNTER6
Default's are COUNTER1: 101, COUNTER2: 103, COUNTER3: 201, COUNTER4: 203. COUNTER5, COUNTER6 none.
You could try entering those counters.
The counters could have been reset. It is apparently possible but certainly not advisable to do so without permission from Canon.
Jul 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How to Find Canon iR400 Total Copies Volume
there are two types of counter : mechanical total counter is infront of the machine just open the frontdoor cover its on the left side if there is 3 counter , the topmost counter is the total.
if you want to see the e-counter press *(with head)> 2&8 at the same time then* (with head)the display will change press COPIER>COUNTER you will see all the counter, usually this counter does not match with the mechanical one
Jul 12, 2009 | Canon imageRUNNER 3035 Black and White...
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
Afficio 250 SC900...copier will not operate
Is the SC just 900 or is it SC900-01? If it is 900 then it is a total counter error stating that the machine exceeded 9,999,999 copies. If the machine does not have this many copies then the NVRAM is defective. If the SC is 900-01 then the total counter is not working properly. Causes could be .... the mechanical total counter defective, mechanical total counter disconnected, or a poor connection at the total counter. Hope that it is the latter of the 2 codes.
Jan 03, 2009 | Office Equipment & Supplies
An error in NP 6050
E030 Does pertain to the total copy counter.If you have changed the dc controller & copy counter & still get the E030 error, you may have to enter the service mode to release the error. In service mode under *4* (function) advance to the error screen & press the star button. If you do not know how to get into service mode you can email me at bspier@carlsonsupplies.com or call Bill @ 315-701-1279 Please put canon 6050 E030 in subject line in case my email dumps it into the junk folder.
Aug 13, 2007 | Canon NP 6050 Copier
Toshiba E-Studio 2040c Copier Logo
62 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
