W2353v driver - Computers & Internet
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
My monitor slows down
Sounds like an issue with you PC not the monitor.
Try updating your display/graphics card drivers.
Welly250
Jul 02, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
When i connect my pc to my monitor (LG w2353v-pf) via a HDMI cable the monitor tells me to check signal cable. I know my HDMI cable is fine since i have tested it on my TV. also i know that my computer...
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
Apr 13, 2011 | LG W2353V-PF 23' LCD Monitor
I have a lg monitor flatron w2353v and non of the controls are response any more. do you know anything? thanks!
clean its control with thinner using prush teeth be cureful monitor is crt not lcd if lcd is worong
Mar 27, 2011 | LG Computers & Internet
My monitor (LG Flatron w2353v) is stuck in a 4:3 aspect ratio. I turned the computer on this morning and for whatever reason, it was just like that and I cannot seem to get it back to 16:9. I have tried to...
Install fortemanager and set evreything back to factory presets. After installing the software, you will have to enable fortemanager settings by depressing "f-Engine" in your monitor for about 10 seconds.
Jan 19, 2010 | LG Computers & Internet
Ive got the screen hooked up to my lap top everything looks great but when i play a movie the screen flickers
Screens will flicker during movies if the monitor settings or drivers are incorrect.
Check to make sure that the drivers for that model monitor are installed and up to date.
Go into control panel>display>settings>advanced>Monitor
and try changing the screen refresh rate (Hertz). You can also adjust the resolution from the settings screen as well.
Dec 21, 2009 | LG W2353V-PF 23' LCD Monitor
Flatron W2353V Monitor shows no video feed
My pc has 2 places to connect a monitor, due to the fact that it has an integrated generic quality video card (which didn't quite excite me enough), so I installed a higher quality graphics card. So, make sure that you have connected correctly.
Also, there should be an INPUT MODE selection somewhere on the monitor itself. Mine has a series of buttons on the lower right side, one of these is INPUT.
On a side note, you may need to download drivers for it; I have located the manual and drivers for this item here:
http://www.lge.com/us/computer-products/monitors/LG-lcd-monitor-W2353V-PF.jsp
Hope this helps.
Dec 15, 2009 | LG Flatron L1510S 15" LCD Monitor
ForteManager problem (LG monitor software)
I uninstalled the Forte Manager through the control panel as I was having recognition problems with my W2552.
It has solved the problem, and I have had no problems since!
Sep 24, 2009 | LG W2353V-PF 23' LCD Monitor
Computers & Internet Logo
David Payne
David Payne
