Question about Watches
Set time armani watch
I bought Ax1281... Plz let me kno how to set hour day etc... Using two buttons around the crown
  • Oscar Sandoval
    Oscar Sandoval May 08, 2017
    Did you got it? i been trying to change it for weeks! can you tell me how to change time
4 Suggested Answers
SOURCE: columbia watch - set time
Hope this helps!
I found it finally!!!
Good luck, I hope this helps you!!!
Columbia by Fossil Customer Service Contact
Contact this seller Phone: 800-449-3056
Posted on Jan 11, 2008
  • 4 Answers
SOURCE: changing time-for day lights saving time on watch
A. Press and hold MODE until HOURS digits flash (you’ll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
Posted on Nov 08, 2008
escapement
  • 2334 Answers
SOURCE: Is there an easy way to change the date on my
Of course, there is the way to do that. Try to pull out crown carefully and you will notice that there are two positions (clicks). Second click is when the crown is fully pulled out and the watch hands move by turning crown. But there is first click (lets say - crown is pulled just half way out). In this position the date/day can be quickly changed by turning the crown. Crown=winder.
Posted on Feb 27, 2011
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
Stopwatch second hand not reseting to zero ar 0532
PULL THE CROWN OUT TO SECOND POSITION THEN PRESS THE START BUTTON TILL IT GETS TO ZERO THEN PUSH CROWN BACK IN
Sep 13, 2013 | Giorgio Armani Emporio Armani Sport Ar0532...
24 hours hand in advance of 2 hours from the hours hand
You need a watchmaker. This probably occurred when you had a dead battery replace. It is possible to reset the different hands through a procedure involving pressing different buttons with the crown in different positions.
Oct 07, 2012 | Emporio Armani Watch AR1400 Cronograph...
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
My Emporio Armani 5330 has a problem in that the date advances at noon instead of at midnight so the 24 hour indicator on the bottom of the face is not in sync. How do I correct this?
Simply advance hands 12 hours forwards (clockwise). Just pull out crown to the time setting position and turn the watch hands forwards if the date is changing before midnight. If the date is changing after midnight - turn the hands 12 hours backwards. Don't do this when the actual time is between 10pm - 2am.
Jun 02, 2011 | Giorgio Armani Armani Bracelet watch...
How do i set the day (Mon-Sun) on my ax2013 watch?
When you pull the crown out there are two positions. The first is the day/date setting position. Turn the crown one way and the date changes, the other direction the day of the week changes. Set both the day and date to yesterday. It will become evident why when you finish. Now pull the crown all the way out and notice when you turn the crown the hands move. Advance the hands to the 12 o'clock position in a clockwise direction. As you pass 12 the date may begin to change. If not then you now know that was noon and not midnight because the date only changes at midnight. If the date did not change advance the hands all the way around 12 hours. This will now be midnight and the date should begin to change. It may be almost instantaneous or may take until 12:30 or so. Continue advancing the hands to 4 o'clock. You should see between midnight and 4 the day of the week advance. Now the day/date are correct for today and the final step is to set the correct time. Remember, you are now set a 4 AM. Advance the hands to the correct time. That means if it is 3 in the afternoon, you must advance past noon to 3. You cannot go backwards. That would be 3 AM!
Mar 24, 2011 | Giorgio Armani A|X Armani Exchange Black...
Setting Time
Hi, You can set it using the digital read, pull the crown one click then select the county you are in. To amend the time pull the crown fully out and use the 2 buttons to select the second, hours or minutes then adjust by turning the crown itself. It should automaticaaly set the time for you when it picks up the remote signal, normally around midnight.
May 22, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
