Question about Optics
Winchester 41037a what tipe of wood was used for stock
What is my Winchester 94 serial 4087, 1/2 octagonal barrel worth
Condition and caliber? That's a first year gun so should be 38-55. Is it full or half magazine? Take-down or solid frame? What but-stock rear end plate? t(sheesh, fixya!) Checkered or plain stock? Barrel length?
CONDITION is 90% of the price.
Feb 16, 2015 | Winchester Optics
Looking for the date of manufacturing.model 94serial#4421549
Winchester Manufacturers There are many legends about why the historic serial number records for Winchester rifles and shotguns are not complete or why they are not always verifiable. A few reasons cited are
A fire at the factory
Inadvertent destruction during office cleaning
Records simply lost in filing
Records misplaced between ownership transitions
Documents borrowed but not returned
The seven digit numbers began in 1927, most of model 94 serial 44 series began in the 1970 era. The Cody Firearms Museum has more information on Winchesters produced before 1900.There are other outside resources including the Cody Firearm Museum which can be excellent for determining date.
When you take apart your rifle you might find more numbers in the wood stock that supports the barrel. Good luck
Feb 02, 2015 | Miscellaneous
What caliber is my model 1876 winchester riffel
Winchester - Model 1876
  • Winchester 1876 .45-60 (W5880) Winchester 1876 .45-60 caliber rifle. Made in 1883. Unusual gun as it has a half round half octagon barrel which is something you rarely find on a 1876. Gun is excellent with approximately 97% of the original finish. Wood is...
  • Winchester 1876 .45-75 (W2960) Winchester 1876 .45-75 caliber rifle in 35xxx serial number range with 95% blue overall and excellent wood. Has a tiny T.J.H. on receiver. This is a top condition '76 with factory letter.
  • Winchester 1876 .45-75 (W3037) Winchester 1876 .45-75 caliber rifle with very good wood and metal. Rare 7 leaf sight called for in factory letter. Rare 7 leaf sights are found on some 73's but not mentioned in the factory letter.
Aug 29, 2014 | Foam Mattress Discounts 10 King 5 Lb...
Model 94 winchester values
Post '64 winchesters command a lower price than those made previously. Perfect condition would bring ~ $300 or so. Checkering on the stock would increase the price slightly. You have the most common version of the '94 Winchester made.
Dec 21, 2013 | Optics
Can't remove stock from Rossi single shot
Remove the butt plate (should be 2 screws), shine a light down the stock bolt hole to determine if you need a socket and extension or a long screwdriver. Use the appropriate tool to remove the stock bolt. Righty tighty, lefty loosey.
Oct 02, 2013 | Rossi 308 Winchester Single Shot w/23 Blue...
I have a winchester model 04-22- short with a broken stock . no serial # Where can i find a good stock ? Fred K.
i know little about guns but if you still have the peices try gorrila glue,be sure tofollow the instructions on the bottle. or agood two part epoxy. otherwise try cabelas or online at winchester.
Nov 28, 2010 | Sport & Outdoor - Others
What is the torque specs for a Winchester Model 70 xtr triger guard asmbly .338 Winchester Mag?
For HVB or custom pillar bedded stock, HS Precision recommends 65 in lbs. Other 3rd party stocks are 50 in lbs and Winchester recommends 35 in lbs in the post 64 manual.
And the #Gxxxxxxx rifles have unknown manufacturing dates. They were made by a company that never said what the year ranges were on the numbers.
Jul 18, 2010 | Sport & Outdoor - Others
Removing bolt from a winchester model 67
Pull stock off your model 67 win. The trigger stays in the stock . Lift up on the barrel and action while pulling it toward the end of the stock. To separate them. Next open the bolt , then reach under the action grasp the arched piece of spring steel . Pull down gently on the spring steel retainer while pulling back on the bolt. You can also remove the ejector assembly in the same manner pulling down on it. Assemble in reverse order.
Mar 31, 2010 | Winchester (026196062448) (20 - 60x70 mm)
Optics Logo
27 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
