Question about JBL Radial Speaker Dock Docking Station for Apple iPod - Black - JBLRADIALBLK (050036912372)
Jbl stage ipod dock
The sound output is distorted at all sound levels particularly with music with heavy bass sounds
  • 4 Answers
SOURCE: JBL PSW D112 Distorted Sound
SYLVAN.
THE FILTERS /FILTRES ON YOUR SPEAKERS ARE TORN OR DAMAGED. IF YOU STILL HAVE WARRENTY ON THEY FROM JBL YOU CAN RETURN THEM FOR NEW ONES, PROVIDING THAT IS COVERED. IF NOT. I PERSONALLY RECOMMEND YOU BUY YOU SOME NEW ONES. REPAIRING WOULD BE OK, BUT IT WILL HAPPEN AGAIN VERY QUICKLY.
Thank you. Let me know what your decissions are
Posted on Nov 24, 2007
SOURCE: JBL on time
No luck finding repair, so have accepted that mini jack into ipod and aux-in socket in on-time will have to do. My daughter is satisfied!!
Posted on May 23, 2008
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Posted on Mar 11, 2009
  • 6 Answers
SOURCE: can you repair a broken ipod connector on the JBL On Time?
Yes it can
Fullers Electronics on 01728 746400
The board part number is: ZDTIMEWT0100G
Posted on May 06, 2009
SOURCE: will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Posted on Jun 19, 2009
Hi. I just bought a new JBL On stage micro III. The problem is that when I put my Ipod on the dock the sound only comes from the iPod and the speaker doesn't produce any sound at all but when I push...
Have you made sure the dock is compatible with the iPod version you have? If you are having to move the iPod around, this may be because the dock isn't built for the iPod you own.
It could also be a technical fault that the dock is loose. Take it/send it back to the shop and explain your problem.
May 06, 2011 | JBL 6-1/2\ Round Coaxial Speaker By...
How do I connect my radial JBL to laptopp, i.e. how i get the sound from my laptop on the JBL pls?
i need to connect my ipod docking device to my laptop in order listed my music from the laptop louder throygh the device. i bought a usb cable in order to connect the lap top to the jbl device ?
Apr 17, 2010 | JBL (JBLRADIALWHT) Speaker System, Docking...
How to connect pendrive usb to JBL ipod dock
Buy a universal USB cord which has many different connecting ends. Easily available in electronic shops.
Connect USB 2.0 to the pendrive and the other end to JBL IPOD dock
Nov 23, 2009 | JBL On Stage Micro Portable Speaker Dock...
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Jbl radial dock connector broken
I have the same problem, but I got round it instantly by plugging my ipod into the speaker via the headphone port on the ipod and into the audio port on the speaker. The speaker came with a spare lead as you can plug any music player into it this way. The sound quality seems exactly the same and I dont have to throw away the speakers, hooray! If you have lost the lead you need a 3.5 mm male to male headphone lead, just pence in any electrical shop or amazon!
Aug 15, 2009 | JBL Radial Speaker Dock Docking Station...
Amplifiers GT Series GT5-A604 ........explain settings
the amp probably has a x-over knob, a bass boost knob, and an eq knob. the eq is probably an internal crossover switch that will take the output from either high range (tweeters) or full range (6x9s) or low pass (subs) leave it on low pass. the bass boost however, will add distortion if turned up too high. its not noticable in the car, actually it sounds louder in the car but if you open the trunk and listen, you can tell its distorted bass and actually frying your speakers. the x-over knob is used to tune the frequency at which the amp stops pushing out bass tones. if you like rock music loud, turn it up higher, if you like low deep rap bass, turn it lower. keeping it too high might give you bad sound from either type though. ALSO THE GAIN OR LEVEL.IT IS NOT TO MAKE YOUR SUBS LOUDER IT WILL BLOW THEM .the gain is used to set your amp to your head unit which there is a procedure to do it.
Jun 15, 2009 | JBL GT5A604E 4-way Car Amplifier
Will the jbl on stage micro charge the new ipod touch
Feb 27, 2009 | JBL On Stage Micro Portable Speaker Dock...
Nano not compatible with On Stage
It will actually work, however, you will not be able to dock the iPod® Nano into the JBL On Stage™. You can connect the audio in cable to the headphone jack of your iPod. That's the only way, hope this helps. Pls rate solution. Thanks!!
Jun 12, 2008 | JBL On Stage Micro Speaker Dock for Apple...
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
JBL On Stage for iPod
Hi, I guess that's just a problem that can't be solved by yourself, you'll probably have to bring it back.
I have thesame speakerset, but I don't know how you can remove that thing where the ipod stands in. That plastic thing that comes in a lot of different sizes. I hope that you can help me with removing it and putting an other one in.
May 25, 2008 | JBL On Stage Micro Portable Speaker Dock...
JBL Radial Speaker Dock Docking Station for Apple iPod - Black - JBLRADIALBLK (050036912372) Logo
26 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
