Toshiba DKT3010SD Corded Phone Logo
Posted on Jun 07, 2009
Direct dialing I have a small office with 5 lines. I would like to set up a choice for the callers to reach the relevant section of the office (Billing, nurse, receptionist, managet etc) how do i do that.
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
6262
Points
28
I'm almost positive that what you are talking about is called an "Auto Attendant" or "Automated Attendant" which is a feature that is built in to most Voicemail cards, (e.g. IVP8, Stratagy DK, ies16, etc.). If you don't have a voicemail card, you need to get one for this feature to work. You also may have to have a technician set up your voicemail card to have the auto attendant feature on, or you can do it yourself, if you know how to. if you aren't really sure how to do it yourself, I wouldn't take a chance as you may mess up your system.
Hope I was able to help!
What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue:
Check for a dial tone:
1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone.
If there is no dial tone, press Hook again and proceed to step 2.
If there is a dial tone, press Hook again and move to step 4.
2. Verify telephone cord/line connection:
Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side).
If the cord is already in the LINE port, proceed to step 3.
If it's connected to EXT, remove it from there and connect it to the LINE port.
Press Hook and check for a dial tone.
If still no dial tone, proceed to step 3.
If there's a dial tone now, move to step 4.
3. Test with a known working telephone:
Disconnect the telephone cord/line from the LINE port on your machine.
Connect it to a known working telephone and test for a dial tone.
If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider.
If there's a dial tone, reconnect the cord/line to the LINE port on your machine.
If still no dial tone, consider warranty and service options.
If there's a dial tone, proceed to step 4.
4. Remove splitters or other devices:
Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack.
If yes, remove them for testing purposes.
After removing any devices, continue to step 5.
5. Adjust Compatibility settings:
Press Menu/Set.
Navigate to Miscellaneous > Compatibility.
Choose Basic (for VoIP).
Press Menu/Set and then Stop/Exit.
6. Send a fax:
Insert the document face down in the Automatic Document Feeder (ADF).
Adjust paper guides to fit the width of your document.
Enter the fax number using the dial pad.
Press Fax Start.
Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance.
If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider:
Epson WorkForce WF-2750DWF:
This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen.
Features: Print, copy, scan, and fax.
Scan resolution: 1200 x 2400 dpi.
Dimensions: 16.73 x 14.17 x 9.06 inches.
Weight: 14.55 lb.
It's a budget-friendly choice for home and office use.
Brother MFC-L6800DWT:
A high-speed monochrome laser fax machine with additional features like printing and scanning.
Ideal for small offices.
Check out its performance and ease of setup.
Canon TR8620:
A multifunctional all-in-one printer, copier, and fax machine.
Offers versatility and functionality for various tasks.
Consider it if you need a reliable fax solution
3answers
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
1helpful
Incoming calls unable to answer and wrong calls going to other lines in office, where shouldn't be.
Hello, Nikki -
If all 3 phone lines are land lines, then you should contact your telephone service provider (technical customer service) because there is probably some problem with the exterior phone line connections. The wiring in the exterior connector box was probably negatively affected by your power loss.
Best wishes.
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
NEC Electra Elite IPK B64-U20 KSU
I have a PRI and am asking the same question. I do know that you do have to go into programming to set this up. You also have to have a COIB card installed for this to work for standard Direct Inward Dial lines.
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
What does a DICA card look like? I need to remove it so that callers do not have the choice to dial an extension, but instead it will go directly to our operator...
It's a DISA (Direct Inward System Access) card and you don't. All you have to do is just turn it off in software. In C.O. programs 414-416 or 3.1 in the Maintenance Console, you make sure that no lines are pointed to DISA and probably set to Normal and the system will ring normally.
Carl
Callers are not prompted to general mailbox
Under greeting table 1 set your greeting attendant assignment as 100,that should send the caller to mbox 100 if they press 0 or make no selection at all
How do I display my main number on all lines for caller id?
It's not in the maual, because it's not part of your phone system unless you have PRI trunks. On standard loop start central office lines, it's a function of the dial tone provider. Carl
Cannot fax
Is thi sin an office?
Are you using a direct outside line or is it an office extension?
Your office extension may have restrictions on it and you would need to remove those.
I would confrim the numbers are fax numbers and that that line is ok by:
  • Dialing those fax numbers from a working phone line other than the fax machine
  • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
