Question about Cameras
Ben Q camera GH600 won't function. Its stuck eitherin on or off position.
When i open the camera it makes sound and shuts down even with new batteries It works fine when viewing photo.
Perhaps you should investigate if nothing is wrong with the lens barrel. If it got stuck in any way, and it can't move out, the camera goes in protection, to prevent more damage.
If you say you used new batteries, the must have been out. The most usually way to reset a camera, and recover from an error is to remove the battery for a few moments and then switching on again.
Jul 17, 2014 | BenQ GH600 Fashion Chic 21X Optical Zoom...
Frequent low batt
Check to see if the manufacturer recommends a specific type of battery such as a lithium ion or Ni Cad - Nickel Cadnium.
Apr 18, 2014 | BenQ GH600 Fashion Chic 21X Optical Zoom...
My Ben Q GH 600 got shut down due to old batteries. Now it is not starting despite having new batteries.
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Feb 01, 2014 | BenQ GH600 Fashion Chic 21X Optical Zoom...
How to i determin the problem in my beng gh600 digital cam
What is it doing that you don't like? The manual is here: ftp://217.21.255.101/camera/manuals/gh600/gh600_en.pdf
Mar 26, 2013 | Cameras
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
