Question about Liberty Pumps LCU-20S Condensate Pump 115V Automatic Shallow Pan w/ Sa
Utilitech pro automated condensate pump runs too frequently...why
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
My alarm light is on and my Utilitech Pro condensate pump will not work
One possibility is that the pump outlet check-valve is blocked. The pump outlet is the piece where the vinyl outflow tubing is connected in the picture below. (Sorry for the poor picture quality - all I had at the time was an old flip-phone.)
Disconnect the hose from the outlet:
Remove (unscrew) that barbed nipple that sticks out:
When you've removed the barbed nipple from the outlet, you'll see a rubber piece inside the bottom of it; that's the check valve:
Slide the check valve out from the hose nipple:
And clean out any crud inside the check valve; mine had a pretty solid plug of gunk in it which was blocking any outflow causing the alarm light to turn on: alarm-light-utilitech-pro-condensate-nyw3o5stmcs3jtwvn2n1bid1-3-27.jpg
Now just reassemble and the pump should function properly.
Note: If this valve clogged once, it WILL clog again. I have a very short vertical run of output tubing before dumping overboard (about 1 foot), and I reassembled my unit without the check valve and everything's fine. For significantly longer vertical runs of outlet tubing before it dumps overboard, you'll have all the condensate in that vertical run draining back into the pump reservoir when the pump shuts off if you don't use the check valve - this could cause the pump to short cycle. Also, if there is a possibility of external water siphoning back into the pump reservoir, you'll have to re-install the check valve - but at least you'll know what to do next time it clogs.
- Dave
Sep 14, 2014 | Utilitech 0.33-HP Thermoplastic...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Utilitech pump wont build pressure
my pump does not hold pressure when the water is running cuts on at 20psi and the pressure keep droping.
Apr 13, 2014 | Utilitech Plumbing
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
Pool in off mode but pump keeps running.
Replace filter pump relay if you have an automated system.if you have a timer it is not wired correctly
Sep 16, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Liberty Pumps LCU-20S Condensate Pump 115V Automatic Shallow Pan w/ Sa Logo
79 people viewed this question
Top Liberty Pumps Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Liberty Pumps Plumbing Expert? Answer questions, earn points and help others
