Question about Pride Health & Beauty
Batteries wont charge
Bought new batteries went to charge them the charger says it's charged but they haven't I've bought a new charger as well
  • Pride Master
  • 10,137 Answers
If there is less than 10 volts on the new batteries, then use an automotive NON automatic battery charger to charge the batteries individually.
Posted on Sep 03, 2017
SOURCE: My blackjack wont charge
I did a hard reset because i was having the same problem with a new battery and a new charger. I took my sim card out first to prevent any possible data loss. then followed the following steps:
  1. Once the handset has rebooted to the Today Screen, enter the following code: *2767*3855#. The handset should display a message “Formatting- Please wait a moment”.
  2. The phone will reboot after the Full Reset as this is normal operation.
after i did that i plugged in the charger and it worked perfectly. this is the last step that you would do after updating the software on the BJ
Posted on Jul 11, 2008
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Posted on Nov 27, 2008
  • 118 Answers
SOURCE: New batteries, fully charged, still wont work
I have the book if you can figure a way to post you email without getting too much SPAM. Be sure the charger is un-plugged, and that the free wheel lever is engaged.
cadman000
  • 607 Answers
SOURCE: 98 cadillac deville battery wont hold a charge
sounds like a 12V drain on the system, like a trunk or glove box light that won't shut off.> Could be many. many other reasons why. The way I would find the draining circuit would be to remove the neg cable of the battery. I then would connect a 12V test light between the neg battery TERMINAL and the neg battery CABLE. With a 12V drain the light will shine. I would install into the light a 9V battery powered recepticle to hold computer and radio station memory. Then I remove fuses 1 at a time, then reinstall, at the same time looking for the 12V light to go out. Hope this helps.
Posted on Apr 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: Will work with charger just wont charge battery!
replace the charger. It may have weak or broken internal wiring, loose connection end, or it is just fried out. You can use a multi-meter to test charger. If charger is good, than you may have bad capacitor inside psp
Posted on Jun 05, 2009
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Kodak easyshare dx6490 charger indicator light is on but battery wont charge
Sounds to me that if you bought 2 chargers then you have a bad battery. what are the odds that you have 2 bad chargers ? Time to buy a new battery.
Jan 25, 2013 | Kodak EasyShare DX6490 Digital Camera
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
Packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Apr 04, 2012 | Computers & Internet
I haven't used this camcorder in a couple of months (bought new in January). When I went to charge it last night, neither the mains charger or USB lead will charge it. Does it just need a new...
The battery should be good if it was bought in January, with that said nothing is nperfect or lasts forever, there are always issues with some things. If all your connections from the charger or USB are good and tight and the cables are good, the either the battery is bad or the plug in on the camera is bad, or the battery nmay be installed incorrectly. That is about all there can be .
Jun 03, 2011 | Cameras
My nikon coolpix camera battery dided and now when i plug it in to the charger it wont charge. is there some sort of reset i can do?
If you haven't use your Nikon Coolpix camera battery for a long time and now there is no power, when you first plug it to charger it maybe show none action. And charger longer it will be well. But if your battery Nikon camera battery are used well these days, and it won't be charge. It means you need a new Nikon battery charger
Apr 29, 2011 | Cameras
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
The phone wont charge. They told me to get a new
I think the problem is with the charger, if you can visit your dealer , check out another charger in the shop, and get a replacement.
I hope i`ve helped.
Dec 06, 2009 | Motorola Mobility SIDEKICK SLIDE Cell...
My blackjack wont charge or turn on
i think you should also change your battery so that you will know if the problem is with the charger of the battery.
or may be the charging pin is the problem or is broken, so you should try and check all.
Jul 20, 2009 | Cell Phones
Psp sont charge.. new battery
try a new charger if that dosnt work take it into a shop that sells them and try ask them if they no wat to do
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
Health & Beauty Logo
24 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
