Lg direct drive 7 5kg wm 12225fd fault OE showing on display
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
SOURCE: lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Posted on Aug 12, 2008
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
  • 2468 Answers
SOURCE: what causes an lg direct drive not to spin
your tub needs to be totally empty of water first,if it is then open the top cover and run the diagnostics on the unit,if this fails then the control board is defective
Posted on May 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Hi.my lg 12225fd has recently started showing oe and wouldnt drain, it has now stopped altogether and just makes a quiet humming sound. Is it something minor.
Normally humming sound means blocked motor.
Don't use it any more until you find the root cause, otherwise you could burn that blocked motor.
Most probably is the water suction pump, Open the filter container and clean it.
If continues to humm it needs to be open and clean inside.
Do it before it burns to avoid additional costs....
Regards...
Dec 01, 2015 | LG Washing Machines
What causes the EO error message
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 04, 2014 | LG Washing Machines
My LG WM 2010CW washing machine is showing this error "OE".
You have some drain problem, check drain pump, drain house, filter
Good Luck
Mar 15, 2013 | Facebook Apps
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
OE ERROR CODE APPEARS ON DISPLAY ON MY LG FRONT LOAD WASHER
Oct 14, 2009 | LG WM-2277HW Front Load Washer
Lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 28, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
