Question about Maytag Ovens
How do I replace the bottom oven element on my Maytag CWE5800?
The element on my Maytag CWE5800 double oven started sparking and a small flame started to work its way around the element, sparking the whole way.
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 650 Answers
This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
Posted on Mar 02, 2014
4 Suggested Answers
  • 146 Answers
SOURCE: F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Posted on Dec 21, 2007
SOURCE: MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Posted on Dec 18, 2008
Maytag317
  • 1136 Answers
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Posted on Jun 20, 2009
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
Maytag oven, top door has lost the middle open position, falls freely and does not close well on its own. Model cwe5800ace. How do I access to inspect and/or repair?
Here is the body parts diagram of the Maytag CWE5800.So this will help you out in more depth.Please the link to so you can see other parts how it is linked to door too.
Click here to get to the body parts diagram.how to assemble it.
Hope this will help you,
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | Maytag CWE5800A Electric Double Oven
I turned the bottom oven on and it was like a small lighting bolt went off, it tripped the fuse box to the house and now only the top oven works?
You will probably find that the element for the lower oven has expired. They sometimes do go in a shower of sparks. I once had an element on a hob explode in my face and a small lump of red hot metal flew up and just missed me.
It is easy to get to the circulatin fan and element, you just have to remove the 4 self tapping screws in each corner of the fan/element cover for the cover to come off. If the element has burnt out as you say you should see some evidence of burn marks/holes on the element.
The bad news is that you will have to take the whole oven out of the housing to remove its top and back to gain access to the element retaining nuts and the wiring to unclip/reclip it.
Try espares for a replacement element and if it was a major bang when it went, you should consider replacing the thermostat as well as this is often damaged by the element going.
(The thermostat is the long thin metal rod in the top right hand corner of the oven and is connected to the control by a very thin fragile pice of wire - be careful)!
Sep 06, 2010 | Stoves 720EF Electric Double Oven
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
We have a double the top oven and broiler will not heat up, the timer light are working. also, the bottom oven is working
You probably have a bad element. Take care how you replace it because a live 240 volts goes to it and then the elements:
Mar 28, 2010 | Maytag Ovens
Oven burner seems to not shut off. For a while burner started to spark and even put out a small flame. Is this a depper problem than just changing the burner. Oven is 14 years old.
I don't think so ofcourse there could be something else that could be damaged because of the defective element. They start to develop hot spots whent there is food splashes that get on the electrical element and that splash is the area where most of the heat builds up till the resistive element burns a whole and that's when the sparking starts.
Jan 20, 2010 | GE JTP15 Electric Single Oven
Bottom oven not working Tecnik 8525/2
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Tecnik TKC8525 Double Oven
Ovens Logo
107 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
