Question about BaByliss Health & Beauty
Babyliss t73c adjustable head has not been moving properly for a while and now will not switch on at all.
The t73c shaver has an adjustable head which can be changed using up and down controls to get a specific height of beard. Last week however, the control would not get above 2.5 millimetres without making a whirring noise and promptly switching itself off. The shaver is now not turning on at all, despite being charged.
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
  • 3 Answers
SOURCE: charging stand
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Posted on Sep 14, 2008
  • 7 Answers
SOURCE: my Braun Syncro 7526 pop up trimmer stopped working.
There should have been a little tube of oil in the package when you bought it. the baldes dry out and then won't move. take the oil and run a small amount acrossed the blades. let it sit for a few seconds and then turn it on. once the oil lubes the blades, they should start moving again.
Posted on Feb 16, 2009
MsCtrl
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
brector3
  • 1600 Answers
SOURCE: Braun 7570 shaver won't switch off!
Most likely, the switch mechanism is broken inside and will need to be replaced. This part comes with the outer housing of the shaver and is available at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jun 29, 2010
BaByliss 2082CU Pro 235 Hair Styler these won't seem to heat up enough on highest setting, brand new
Enter the serial number on the babyliss website to ensure you have a genuine hair styler, if genuine ask for your equipment to be swapped or repaired at there cost
Feb 23, 2015 | BaByliss Health & Beauty
Babyliss instructions
Manuals here: http://www.fixdevice.org/manuals/brand/babyliss.html
Faq here: http://www.babyliss.eu/support/
I'd give you a better answer if you had more details in your question. I'd need to know specifically what product.
Aug 30, 2014 | Health & Beauty
Need replacement foils for model 8667BU as mine is broken
hi my foil babyliss machine was broken how can iget new foil for model 5667bu
Jul 09, 2011 | BaByliss 8667BU
I have lost the charger for my Babyliss 7053u, where can I find a new one?
A new kit is fairly cheap: http://www.amazon.co.uk/BaByliss-Men-7053U-Over-Grooming/dp/B002FGTJ0O
I couldn't find just the charger anywhere... I would recommend just buying a new kit.
Apr 21, 2011 | BaByliss 7053U Beard Trimmer
My babyliss 789ou has lost the ability to set adjustment,this happened after travelling
This commonly happens to travelers. The voltage of electrical outlets differ depending on where you travel. Shavers bought in one country are specifically designed to handle the outlets of that country but plugging into a potentially higher output outlet you blow out the motor of your shaver which it seems like you did. The only real solution would be buying a new shaver. It had nothing to do with the shaver itself, simply a mix-up in charging the battery which caused the motor to overheat.
-Jord
Feb 28, 2011 | BaByliss Health & Beauty
My forfex clippers won't hold a charge
How old are the clippers? Babyliss have a one year warranty on all their electrical goods. It sounds as though you may need a new battery. Have you checked the charger itself to make sure it is working properly?
Jun 10, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Health & Beauty Logo
70 people viewed this question
Top BaByliss Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
