E8 code on MPI monitor heater - Heating & Cooling
4 Suggested Answers
SOURCE: operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Posted on Feb 08, 2008
SOURCE: have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Posted on Nov 05, 2008
  • 4 Answers
SOURCE: MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Posted on Dec 31, 2009
I have an mpi monitor heater flashing e-17 code..... Any ideas?
You probably have the GF1800 or GF3800 model.
The E-17 code means: Flame Failure
Possible Causes:
There are obstacles at circulation air inlet or outlet.
Fan cage is clogged with dust.
Gas pressure dropped when other gas
appliances are turned on.
Nov 02, 2016 | Computers & Internet
Monitor MPI it flashes F 13 or 14 & smells, I had it cleaned 6 months ago
The codes are "E" Codes. an E13 is no fuel. E-14 means flame rod malfunction. Unplug the heater then reconnect, this will reset the heater. Try your red prime button. Could also be the fuel pump or your fuel source feed line isn't flowing fuel.
Feb 17, 2016 | Heating & Cooling
E-14 code mpi monitor 2400
It sounds like you have a fuel problem, check to see if there is some kind of blockage in the line or at the tank value.
Jan 25, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
My light won't ignite on my mpi 441 monitor
this morning my heater, monitor 411, was running fine as always.
while it was running the power company came to work on a pole and turned the power off. it was down for about three hours. once power was restored it wouldn't come on.
the pilot light is off but I'm not sure if it's suppose to be while not running.I've tried priming it with three pumps, resetting by unplugging, beleeding the line, all don't work.
it's suppose to be 22f tonight so I could sure use some help.
oh, I have a manual but, of course, it doesn't cover the problem. I also called the company but got a voice mailbox...go figure.
somebody please help!
Dec 20, 2012 | Heating & Cooling
Our mpi monitor started beeping.
Must be an audible low fuel warning. You let the fuel run out and the wick gets destroyed. Very difficult and costly wick replacement, labor intensive I imagine. I have never seen one of these but I used to be a Kero-sun rep.
Apr 19, 2010 | Heating & Cooling
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Jan 05, 2010 | Heating & Cooling
Mpi monitor says e 14
We found the problem. It was gunk on the inside right b4 ignition. Gunk and rust from the tank when the barrel emptied. Thanks.
Apr 12, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Have a mpi monitor flashing a e13 code
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
