Question about Amana ASD 2624 Side by Side Refrigerator
Wheels refrigerator roll
Not able to find new wheels
I want to move my fridge but it's locked in place. How to unlock?
Hello Tina;
My name is Peter. I am a retired field service refrigeration technician.
You did not post your model number which is located on a label on the inside liner wall of your fresh food section.
First remove the bottom grill or toe plate in front of your refrigerator. This plastic piece is either held on with one screw at each end or pop out clips. If clips pull the plate straight out about 2" from each end. This plate is easier to remove with both doors open.
Refrigerator Leveling Screws: Most refrigerators have two leveling screws in the front, one on each side. These screws are for leveling the refrigerator from rolling on the wheels. Turn these screws counter clockwise.
Refrigerator Wheel Locks: Some refrigerators have a lever bar on the outside of the front wheels to lock the wheels in place.
Refrigerator Independent Wheel adjustment Screws: Some refrigerators have two hex head screws on each side. They raise and lower both the front and back wheels.
Mar 04, 2016 | Refrigerators
How to drop the front wheels on the refrigerator
You should be able to remove the plastic grill at the front bottom of the frig exposing the leveling screws which you can adjust without moving the frig.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 13, 2013 | Liebherr CS2062 Bottom Freezer French Door...
How to raise one side of LG refrigirator that has fixed wheels?
Can you take the rollers off and replace with spacers and longer bolts?
May 02, 2012 | LG Refrigerators
CAN NOT LOCK THE WHEELS TO KEEP REFRIGERATOR FROM ROLLING
A refridgerator will roll forward and back you cant lock the wheels. If the floor slants that much you can take little peices of wood or carboard to place in front of the wheels so they dont roll.If you have anymore questions please comment me back so I can further assist.
Jul 28, 2011 | Kenmore Side by Side Refrigerator
Need to unlock wheels
Roll up the stands on the right and left sides of the refrigerator. They are in the front next to the wheels. It should roll fine after that.
The previous post is correct. The wheels themselves do not lock.
Jun 07, 2011 | LG LRFC25750 Refrigerator French Door
Can't roll it out......is there a lock on the wheels?
The wheels are small, if on linoleum or something soft, they will settle in and require a bit extra to get it rolling. Put a rope around the outside, slide it near the bottom, to get a better grip without tipping it.
Sep 28, 2010 | Jenn-Air JCD2389G Side by Side...
We have a built in Jenn Air refrigerator Model #JS48FSDBDA
Remove the kick plate at the bottom, then you will see the head of a bolt this raises and lowers the wheels, I'm assuming your wheels are up turn bolt clockwise. Thier will be a bolt on each side. The wheels are contained inside of a sheetmetal housing. Once the wheels are down you will be able to roll it back and forth. Go to www.appliancehelponline.com enter your model # and it will bring up a diagram of your unit. The diagram needed is the one for the cabinet. Hope this helps.
Mar 05, 2010 | Jenn-Air 48" Side-By-Side Built-In...
Wireless Dell mouse, wheel in middle, 2 buttons, black and silver.
First try to reinstall the updated driver for your mouse. If this does not work, it could be that the mouse is worn out and you may need to replace it...
Mar 21, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Amana ASD 2624 Side by Side Refrigerator Logo
14 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
