Question about Honeywell Heating & Cooling
Honeywell E-10 reading HH - Honeywell Heating & Cooling
What does HH on the outside temp mean on Model 513-1311OT?
HH means that the temp is over the highest reading that it is specified for. That means either the sensor is bad or it is in a very hot place. The maximum temp for that sensor is 122 degrees
May 28, 2015 | Measuring Tools & Sensors
Is the 588ien compatible with a vista 10 panel & can it support the honeywell 5802wxt2 panic pendant ?
Depending on the age of the Vista 10, yes, but you'll have to be quite knowledgeable to make the necessary program changes. Be advised that there have been a number of compatibility issues since Honeywell started changing component designs in recent years without changing the part numbers...good luck.
Dec 09, 2014 | Honeywell Ademco Honeywell 5881en Wireless...
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
Change time
1. Begin on the main sales screen
2. Press the purple MORE key twice
3. Choose OTHER SET UP from the display screen
4. Type in your password if applicable
5. Press the purple MORE key until the display reads SET DATE/TIME
6. Choose SET DATE/TIME from the display screen
7. Type in the date mm/dd/yyyy
8. Type in the time HH:MM:SS in Military Time
9. Press ENTER
10. Press the red CANCEL key
Mar 11, 2012 | VeriFone VX510
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
My DVD drive (Dell GWA-4164B HH 16x DVD+/-RW) will not read DVD's
click on the below link and download the avs dvd player...it is free and a great universal player.
http://www.brothersoft.com/avs-dvd-player-free-44678.html
Oct 11, 2009 | Computers & Internet
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
Mar 25, 2009 | Cobra Radio Communications
Casio qt-2100 add department onto x read
Hi.
You need to link some PLUs to new department numbers, so go into the PLUs that you want to link to hh beer. Link them to the next department number that is unused, so if your last dept is 5, link them to 6.
Then you need to go into the department naming and change dept 6 name so that it appears correctly on your report.
I'm not sure how familiar you are with this machine. It is powerful, so you need to know what you are doing when programming it.
Mark
Mar 14, 2009 | Casio Parts Cash Register PC Desktop
Hh TTY support
You should let the phone ring 10 or more times to allow the Deaf or HH person enough time to see the flashing light and respond to it.
Aug 27, 2008 | Williams Sound PKT D1 H21 Pocketalker...
Scott ZXP8 Eclipse cd mini hifi system
Was the fuse Blown?? check with an ohm meteracross the two prongs that you plug into the wall of course you gotta unplug it for this. It should read around 4 to 10 ohms depending on the type of power transformer is in the unit.. If it reads open then theres a fuse open or a bad power transformer. If its not open check the power supply for the proper voltage from the diagram. Good luck
Apr 16, 2006 | Scott HH SJ510 Freestanding CD/Cassette...
Heating & Cooling Logo
46 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
