Question about Microwave Ovens
How do i install a high point microwave door handle?
How do I take door apart to install handle.
    New Friend:
  • 41 Answers
Look really good on inside of door. You should be able to remove the inner panel and then have access to bolts for the handle? If not... Epoxy is your best friend at this point! Good luck!
Posted on Jun 05, 2014
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacing door handle on Kenmore Microwave model #6656961221
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 25, 2009
taran_2005
  • 10515 Answers
SOURCE: Replace handle on Ewave microwave
A common Guide that would help you :-
http://www.applianceaid.com/oven-hinges.html
Generic Procedure on most of the Ovens :-
Set the door on the ground with the hinges facing up. You will need to push down on the hinges and extend them by hand. It's probably best to put something in the palm of your hand like a handle of a screwdriver so that you can push on the hinge and open it up (you will still have to push hard). When you open the hinge up you will see a tiny hole appear about the size of a pin head. You will need to stick a screw or something inside this hole so that the hing will not close again. When you have both hinges locked out you can then reinstall your door at about a 45 degree angle. Open the door up all the way and remove the screws or pins you placed through the door and then you can shut the door all the way again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 19, 2010
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Kenmore microwave, model 721.62649200. The Handle to the door just broke off. I can find places online to buy a new handle, but I can't for the life of me figure out how to take the door...
I have a similar unit and I removed the outside of the door by loosening two flat head screws on the narrow where the handle is located. There are several screws yet holding the outside plastic housing too. Once these are removed the plastic door will come off. Then the handle will be accessible.
The same issue started with my oven too and I replaced the original handle with larger screws and using a high quality plastic glue.
This held for a while. The plastic door cover seemed to have changed dimensions during its life and warped. I ordered a new door and it lasted a short while. I then asked for a new door under warranty.
Bottom line they wouldn't sent a new cover but they returned my money. Apparently the doors all had crappy plastic issues. Currently we are using the microwave with out the door front. It still works like new after 10 years though.
Nov 12, 2012 | Kenmore 62622 Microwave Oven
How to install WB15X10022 GE Microwave Handle.
This is a generic answer
Open the door and look carefully for a plactic strip that may be covering screws. If none. look on the bottom edge or the edge with the hinge. Remember, someone had to assemble the door so there has to be some way to disassemble it. I have never seen one that can not be opened (glued, cemented or welded closed) Remember, most doors are spring loaded and may snap shut on you with the door partially removed. Also, keep in mind the process you went through to get it apart. You will have to reverse that process. You may want to take pics with your cell phone as you progress.
Once open (and you may need a 'Torx' tool to remove the screws), replacing the handle should be simple.
Let me know how you make out.
a
Sep 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Trying to replace the KHMS155LSS3 handle...
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs._828.jpg_829.jpg_830.jpg_831.jpg
Jul 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Need to replace the handle I have the part but how do i desassemble the door properly
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jun 03, 2009 | Microwave Ovens
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
Feb 12, 2009 | KitchenAid KHMS155L Microwave Oven
Getting door frame apart to install new handle
If you're replacing the handle, then order the choke cover..It's the piece on the inside of the door that covers the handle screws. No matter how carefull you are, it is almost guaranteed to break. If you break it, then you have one, and if not, send it back. DO NOT OPERATE MICRO WITHOUT CHOKE COVER.
Dec 09, 2008 | Kenmore 62702 Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
6,460 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
