Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE stainless Side by Side doesnt cool enough
Almost 9 months back we had the back wall of the freezer filled with ice and we ended up replacing the "heater element".. thats what the technician said he was doing.
But this time, it isnt so bad. I feel the refrigetor side isnt cool enough at a setting of 6.
The freezer side is extremely cold with setting of 4. There is kind of very thin layer of ice on the containers in the freezer.
Also, the back wall in the bottom had small piece of ice.
I switched off the ice maker and cleaned out the little bit of ice buildup  and waiting to see if the ice builds up again.
Any other ideas?We dont use the ice from icemaker. So can we leave that switched off?
Where should I look for the drain pipe to check if its clogged?
Thanks
  • GE Master
  • 4,655 Answers
I had that situation several times until I notice bad wire connections on the defrost element. It may be in the defrost time circuit also. I would watch this closely and be prepared to have a competent service technician be there to service the your fridge when if needed to prevent food loss in the event the problem gets worse, Thanks Sea Breeze
Posted on Oct 27, 2007
  • John Tripp
    John Tripp Oct 27, 2007
    Removal of the ice maker may help give more room and should be off if not used. The drain from the defrost, that should cycle about every 8 hours, is to a pan under the refrigerator. You can usually hear the freezer go into defrost because the compressor stops for about 10 min. and you will hear a crackling noise during the first stage of defrost , Thanks Sea Breeze
Our GE Adora side by side refrigerator is not making ice . Freezer is cold enough but no ice at all
If you don't use much ice, its likely the fill line into the ice maker has frozen. Access the back of the refrigerator, locate the water line going into the back of the freezer. There is probably a clamp holding the line in place. Remove the screw holding the clamp, and gently pull the hose out of the freezer. Let it sit for about an hour while the ice in the end of the water line thaws. After an hour, insert the water line back into the freezer, install the clamp, and start a cycle - there should be an envelope on the back of the fridge with instructions on how to start a cycle. You should be able to hear the water flow into the tray.
Dec 19, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
The refrigerator gets warm, stops cooling, and the back wall of the freezer ices up. I replaced the mothWCFer board, thinking it was faulty.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a ge gsl22wgph and the refrigerator side is not is not getting cold enough and the freezer side is not freezing. What is the problem?
First look at back wall of freezer toward the bottom and see if you have frost build up on the wall. If you do the problem is most likely the defrost heater and you will need to remove back wall of freezer, melt the ice from the coils and then change the heater at the bottom of the evap. coils.
Apr 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSS22UFPWW Fridge is not cold enough 9 is like a 1 in temp
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 27, 2008 | GE Refrigerators
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
