Question about Yamaha Ns-1000m Ja-0513 Beryllium Dome Tweeter Ns-1000
Looking to buy tweeters for my yamaha ns 1000s -ja0513 part no.
4 Suggested Answers
Toufic Malek
  • 9 Answers
SOURCE: Speaker act more like tweeter only, not mid range + tweeter
They are mid Hi speakers.1st Open them and check if the mid speakers are ok maybe they are defected or the protection is open. Good Luck Toufic Malek
Posted on Sep 28, 2007
  • 15 Answers
SOURCE: The tweeters in my yamaha
http://www.partsexpress.com is a popular source for loudspeaker components.
Also, are you sure the tweeter's blown, and not a crossover component?
www.mouser.com carries many electronic components that could be used in crossovers.
Posted on Dec 02, 2008
SOURCE: Monitor problem.
um.. im just gona say this it seems obvious but on mine one of the leads connecting the sub to the rest of the cabinet fell off and all i had to do was reconnect it and it was fine.
Posted on Nov 27, 2009
WHICH ARE THE PERFECT MATCHING BUDGET SPEAKERS FOR MY YAMAHA RX440 AMPLIFIER/ RECIEVER?
You have asked a big question with lots of possible answers.
I am not familiar with your receiver so I don't know the important things about it - such as the power output and the required speaker impedance.
There are other important things to consider too, such as where you live, are there close neighbours, what sort of noise do you like to make and how loud and equally importantly how much room do you have; are the speakers to stand on a shelf, on the floor or be suspended from the ceiling?
Generally the bigger and more solid the speaker cabinet the better the sound is but that would be useless if you have room for only bookshelf speakers.
You said budget speakers. If you want quality sound then budget speakers are the last thing you need - you would be better going to buy some decent used speakers from a garage sale or buying yourself a couple of decent drive units and fitting them into a pair of concrete drain pipes or even lavatory pans or constructing your own cabinets or if you have lots of space just a pair of infinite baffles.
If buying used speakers there isn't much choice; you have to have what is available within reason but if you are buying new it is best to know what you want. There are two basic types of cabinet - the infinite baffle, a closed air-tight cabinet that if well constructed and big will make mediocre drive units sound better and the fashionable type just now, the tuned bass port cabinet that must be well designed and have decent quality drive units.
Both those types could house one, two, three or even four drive units and perhaps a crossover and/or peizo tweeters.
I suggest you do some research and sleep on what you have learned and then ask your question again including a great deal more information.
Oct 02, 2016 | Yamaha Audio Players & Recorders
A replacement tweeter for Yamaha S215V speaker
I generally get replacements from Simply Speakers. Their site is-Replacement by Simply... Genuine Eminence Parts New
You can also just replace the diaphragm. The procedure is on YouTube here-
Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply... Genuine Eminence Parts New
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box.
Feb 17, 2015 | Yamaha S215V Main / Stereo Speaker
Where can I find a tweeter for Yamaha S215V speaker? Thanks
I generally get replacements from Simply Speakers. Their site is linked below.
You can also just replace the diaphragm. The procedure is on YouTube linked below.
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box. Genuine Eminence Parts New Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply...
WHAT WOULD BE WRONG IF A PAIR OF YAMAHA NS-10M HAD NO SOUND COMING OUT, WOULD THEY COST MUCH TO FIX
Hi.
I don't think both speakers are damaged unless, some kind of electric failure affected them, they just must be connect in the wrong way.
Aug 27, 2011 | Yamaha NS-10MT Speaker
Find original replacement tweeter for HB1
just buy the same wattage rating, same ohms rating and most specially the same diameter, price depends from the name, there's a lot on the internet
Jun 07, 2010 | Heybrook HB1 Speaker
How do you install dome tweeters?
tweeters get installed almost like any other speaker. you pick a mounting spot, then mount them, or cut the hole for recessed tweeters, etc. run the wire to the closest speaker wire from your stereo, and just splice it in. you will however need some kind of crossover to prevent the low frequencies from being played through the tweeters. if you buy new tweets, they usually come with their own crossover, or there are a few different styles you can get.there are the passive crossovers, the ones that look like small boxes. there are also the inline filters. these are the ones that you splice into the positive speaker wire to filter out the low frequencies. and some aftermarket stereos come with some kind of filter or equalizer built in, depending on your model. what I would do is buy one of the inline filters for each tweeter. theyre inexpensive, and easy to install, and they work great. so basically, just mount the tweeter, run its wires to an existing speaker wire and splice it in, and install an inline filter on the positive wire for the tweeter. oh, one last thing. if your interior speakers are powered by an amplifier and not by the stereo, then just run the tweeter wire to the speaker outputs on the back of the stereo. too much power will definitely destroy any tweeter. good luck!
Sep 08, 2009 | Car Audio & Video
No tweeter output
sorry but if the woofers work you have blown the mids and tweeters
Apr 30, 2009 | Yamaha RX-V663 Receiver
The tweeters in my yamaha NS-515F have blown. Any ideas where i can purchase suitable replacements?
Dec 02, 2008 | Yamaha NS-515F Speaker
I want to buy a receiver compatible for this NS-BP4500 speaker systerm. Which Receiver should I buy?
if you have the manual for the speakers please try to get the specifications. i suggest that you get a yamaha DSP system for this also.
May 08, 2008 | Yamaha NS-BP4500 System
Sep 22, 2007 | Yamaha NS-A327 Speaker
Yamaha Ns-1000m Ja-0513 Beryllium Dome Tweeter Ns-1000 Logo
Top Yamaha Computers & Internet Experts
Carlos L. Burgos
Carlos L. Burgos
xalint1
xalint1
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
