Question about Samsung Digimax D53 Digital Camera
Help Camera is off, lens is still out, and when you turn it on it beeps and turns back off. I have tried new batteries,but it's still doing the same thing. Do you have any suggetions.
  • tag22 Nov 12, 2007
    i have the same exact problem with my camera. i was out hiking and taking pictures and the batteries died, as they so often do. but when i got back home the camera wouldn't stay on. even when i put new batteries in, i would get this loud beep, or there would be a low battery indication. the lens is stuck and so am i. help.
    Scholar:
  • 97 Answers
Try rechargeables or oxyride batteries, not alkalines. Hope this helps!
Posted on Nov 09, 2007
My camera has a "lens error". It will not contract back and stays out in zoom...it beeps and gives me this message to start, but doesn't do anything.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
Jun 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Beeps three times lens is stuck out and won't come on
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these E18 repair instructions useful, consider bookmarking this page or posting your experience in the posting area. If you have any ideas for improving the web site, so it can benefit more people, feel free to share them with us
Jul 16, 2008 | Samsung Digimax S500 Digital Camera
Why is the camera beeping?
I had t he three beep problem and also the lens was open. I tried batteries - then i noticed the lens was slightly bent - i tried straightening and it snapped and went into place. then i tried turning it on and it was fine and when i turned it off the lens closed.
Maybe your lens is bent.
Jun 28, 2008 | Samsung Digimax S730 Digital Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Samsung Digimax D53 Digital Camera Logo
27 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
