Question about Sylvania LC225SSX LCD TV
Test text1 underline
Black box appear on tv screen text text1 underline
2 Suggested Answers
  • 476 Answers
SOURCE: there appears a black box on screens on certain channels
Hi, hit the cc button on your remote control untill the close caption display says off, this should eliminate the box from your screen
Posted on May 19, 2010
A black square appears on the screen several seconds after turning on. It disappears after changing channels but reappears soon after.
Check your TV settings under Caption, odds are someone adjusted the captions to text1 or 2.. the box should go away after you change that to off or std cap.
Aug 07, 2010 | JVC TM-2703SU 27" TV
Black box popping up on screen
Your closed caption is turned on. The box is a text box. Closed captioning has CC1, CC2, CC3, CC4, TEXT1, TEXT2, TEXT3 AND TEXT4 modes. Each mode has it's own use or screen position. If you have a CC button on your remote, press it until CC is OFF. You may need to go into the TV menu to do this, I'm not certain. At any rate, with a little investigation, you should find the closed captioning feature and discover how to shut it off. Best wishes.
Apr 16, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv screen problem
the problem is in the menu.closed caption is on and in the text mode.go into menu of tv turn closed caption to the off position.
Sep 24, 2009 | Sanyo DS27820 27" TV
A black box is covering half of screen
Look in the menu for the "captions" heading. Once in the closed captions, turn off the "text" heading. This text mode is putting up the black box on the tv
Dec 06, 2008 | Televison & Video
Vb code for automatic number change
You want the code for when you press enter in textbox it automatically change to 1.
I am typing C# code you can easly covert it to VB.Net code
make an event for key press for textbox
and write the followting code in the event
IF textbox1.text = ""
textbox1.text = "1"
End IF
I hope your problem will solve with this If need more assistance let me know. If your problem is solved then don't forget to make answer my thread.
Regards
Nov 17, 2008 | Computers & Internet
BLACK BOX APPEARS IN LOWER HALF OF SCREEN. It GOES AWAY BRIEFLY WHEN CHANGING CHANNELS or adjusting settings.
You have a closed caption setting turned on to text. Its probably near your channel up or down button. Keep pressing it, it will cycle through text1, 2, 3, 4, cc1 and cc2 and off. When you get to off leave it for a few seconds and it should disappear.
Jul 09, 2008 | Toshiba Televison & Video
Black rectangle at bottom of screen when playing dvds on sony dvd player
Had the same problem but was able to fix it by simply doing the following:
"this is closed captions turned on your TV. get your original TV remote and look for a button that says "Captions" or "CC", and keep pressing it until the TV says "Off". if it doen't have one of those buttons, you will need to get into the menu of the TV and turn off closed captions there. It is probably set on "Text1 or Text 2" right now, and it needs to be set on "Off"
Apr 02, 2008 | Televison & Video
Blacked-out box covering 75% of screen
shut off close captioning. the close captioning is in text1 mode and needs to be CC1 in order to work, or shut it off
Mar 25, 2008 | Hitachi 51F500 51" Rear Projection...
SANYO DS32920
Did the black box disappear or disappear and then re-appear?
If yes> TV station is broadcasting a caption text signal without any textual data. > Press the RESET key twice.(Customized settings will be reset to factory defaults).
To retain customized settings just turn captioning OFF.
1. Press the CAPTION key on the remote control.
2. Use the 0 key to select OFF, cap1,cap2,Text1,Text2,or Quickcap.
Feb 05, 2008 | Televison & Video
A black box appears on the screen
The close caption feature most be on and you need to disable it to get rid of the black box,the close caption must be set in any mode for the box to come up,maybe text1 or text2.Go thru the menu options until you get to the CC feature,some remotes have a key to bring it up and disable it.Let us know if you need more information.
Oct 27, 2006 | Samsung TXM1967 19" TV
Sylvania LC225SSX LCD TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
