Question about Sewing Machines
Huskystar 55 the thread is not picking up cotton from bobin and is getting stuck, and will make machine stitches
2 Suggested Answers
SOURCE: Husqvarna Huskystar 207 Sewing Machine not
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Posted on Sep 21, 2011
The User Manual does not have a complete stitch guide. Does my Huskystar 207 have a stretch stich?
FWIW, a stretch stitch is simply a stitch that stitches forward a few stitches and then reverses for a couple and then stitches forward again. Having had a machine with a stretch stitch, I found that using a zig-zag is just as effective and uses much less thread as well as less time at the machine. If the fabric is very stretchy, you can merely decrease the stitch length and increase the stitch width to give the stitch enough space to expand with the fabric without popping.
Viking Huskystar 207 Manuals
Jun 22, 2017 | Sewing Machines
MACHINE ONLY SEWS A COUPLE OF STITCHES THEN IT CUTS OFF THE UPPER THREAD
check your cotton strengh and also your bobin tension other wise it will keep on breaking
Apr 08, 2017 | Sewing Machines
Huskylock 431
Hi Young,
Did you thread the bobin correctly?
adjust the thread tension correctly.
please check the hook sharpness.and did you use correct needle.
regards,
nuwan
Jan 16, 2014 | Sewing Machines
I have kanmore sewing machine its not stiches at all one time noise & stop stiches thered not pick up for bobin its not come out.
Wow. If I understand your attempt at English. Your machine made a noise and now won't sew or pick up the bobbin thread.
First change your needle and make sure it's full inserted and correctly oriented in the needle bar. Do a test stitch on scrap fabric.
If you still have problems.. check the timing. The shuttle hook should just be starting to pass the needle scarf when the needle is at the lowest point of travel.
I hope that helps you. Good luck.
Aug 20, 2012 | Kenmore 15218 Mechanical Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
Sewing with heavy thread, what should the tension be set on?
hi there
the tension depends on thikness of material but you must use heavy thread on needle and thin thread on bobin case .
- you must be sew fiew stitches firist and look if losse stitch from down you must tight tension slowly sloly and if there is losse stitches from upper you must tight screw for bobin case spring slowly slowly until stitch format be agood condation.
best regards
ashraf abozid
aabozid@hotmail.com
Jan 06, 2011 | Juki DDL-8700
Why will my machine not pick up my bobbin thread?
Bobbin or needle threaded wrongly? Is this a new machine? You need to make the first stitch by hand perhaps. Lower the needle into the needle plate by turning the hand wheel and raise carefully. It should bring up the bobin thread on a loop. catch and pull to back of machine. Now you can sew. I hope.
Dec 20, 2010 | Singer Tiny Tailor TT700
The thresd gets knotted and it won't stitch
Rethread your machine
Make sure your cotton runs through the two tension plates
Check that your top tension is set on 5
Make sure your bobbin case is threaded correctly
Lastly, make sure there is no cotton stuck between your top tension's plates(take a long needle and remove any fluff)
Sep 14, 2009 | Singer 6038 Mechanical Sewing Machine
I have a huskystar em10 embroidery machine which wont embroider it will run for so long then the needle will snap, its not the tension
I have the same machine and had the same problem. I was changing my needle about every 50 stitches until I realized that it was the timing. After I learned how to adjust the timing the machine has worked fine. The problem is I have to adjust the timing about every 3000 stitches. I leave the bottom off of my machine because I adjust it so often. If you contact a husqvarna dealer they will tell you that they have to send the machine off to get it adjusted and that you can't do it yourself. I didn't have time for this so I googled how to do it and figured it out.
Apr 06, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
