Question about Oregon Scientific Ws903 Aroma Diffuser
Coloured leds don't work - Oregon Scientific Ws903 Aroma Diffuser
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
The LED screen is showing CHECK INK TANK and will not print. I have a full black cartridge and half a colour one. Also the scanner is not working, nor the copier. None of the buttons when pressed are...
I think it means the waste tank, that's usually on the right hand side under where the cartridges park. You havent stated a make or model for your printer so I don't know exactly.
Thanks
May 05, 2011 | Office Equipment & Supplies
Why blk ink n colour ink lead blink very often
Hi
the black ink led is still pinking , I think that cause you used unoriginal ink and its don't matter ...
Apr 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
HOW TO CONNECT AHDD LED IN ASROCK MOTHER BOARD
Just parallel to Power LED button you find HDD or IDE LED button, the red coloured wire should be top and the white coloured towards reset connection.
Sep 11, 2010 | Zerus Intel Desktop Board D815EEA...
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
The colours look muted and dull when printing from my oki c9300
whipe the 4 LED arrays which stick out from the top when you open it up - with a soft paper tissue -gently, or use proper led-cleaner
Nov 17, 2008 | OKI C9300 Led Printer
Colour problem
Sounds like one or more of the colour drums have had it, do a print of each colour and change appropiate drums
Clean the 4 led heads
Dec 18, 2007 | OKI C3100 Led Printer
Oregon Scientific Ws903 Aroma Diffuser Logo
15 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
