Question about Peavey PV6 Mixer
Can't separate microphone and headphones when recording
How to separate voice from line microphone and sound from headphones when recording?
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
HOW DO I RECORD MY VOICE ON THE CTK-900 CASIO KEYBOARD?
Not according to the manual. It was not made that simple.
However, there are a few ways you can produce a recording of the music with your voice. Either mixing with the PC or Mac sound program, or using the output of the keyboard into a suitable mixer with preamp so you can get your levels correct- then record the output of the mixer to computer, or to tape.
Audacity is a wonderful little Sourceforge program to consider using along with the suite of programs and widgets Casio includes with the 900.
Apr 06, 2012 | Casio CTK810 61 Key Keyboard
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Does anybody know how to fix built-in microphones on rolland BR-600. When I attempt to record, the only sound that gets recorded is noice (hissing sound), and that only after cranking rec volume and mic...
Most of these have a SETTING in the menus that selects the source from different mics and/or line inputs. If the setting is to the line input instead of mic, and no audio is connected to the line input it will act like you described.
Jun 23, 2011 | Boss BR-600 Digital Recording Studio
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
Computer does not recognize it and the mic does not record into the computer... maybe my connections are wrong..pls help me
I have a 1222FX and here is how I have it hooked up. I have a cord that has an 1/8" stereo plug on one end and two mono RCA jacks on the other. The 1/8" end goes into my line in on my sound card. (not the microphone in ). The RCA jacks are hooked to two cords that I made up that have a RCA plug on one end and a XLR plug on the other. The XLR plugs are wired so that they are unbalanced. Pin one is ground and pins two and three are soldered to the positive. I used shielded cable and the shield is soldered to negative on the RCA jack but left unconnected on the XLR jack. This prevents hum. You may be able to purchase premade cables but I made my own. The XLR jacks are plugged into the left and right balanced or unbalanced Main output jacks of the mixer. On your computer click Start then Control Panel. Click Sounds and Audio Devices. Make sure that Place Volume in Taskbar is checked. Place the volume slider in about halfway position if there is one. Click Advanced and a control panel should pop up. It will say Play Control at the top. You will want your speaker volume about half way also. Make sure line in is NOT muted (checked ) and is also about half way up. Plug headphones into the mixer and get a good sound with the microphone you are using. If it is a microphone that requires phantom power make sure you turn the power to the mixing board on first, then the phantom power. Do this with the main volume control all the way off. When the mixer has warmed up for a minute or so you can bring the volume up to get a good sound. When you are done recording, make sure you slide the volume down again. Then turn the phantom power switch off and then the main power. This procedure protects your equipment. On the Play Control volume panel on your computer click on Options then Properties. You will see that it is checked for Playback. Check it for recording. Make sure that where it says Show the following volume controls, it has Playback volume and at least Line In checked. Now check the Recording Controls. Where it says Show the following volume controls make sure that at least Line In is checked. Click on O.K. and your Recording Control window will pop up. Make sure that Line In select has a check mark. Slide the volume up until you get a good sound through your computer speakers or your headphones if you have them plugged into the computer. If you accidentally close this window, Click on the speaker symbol in your taskbar at the bottom. You will have to switch between Play Control and Recording Control as before. You didn't mention what software you are using so I advise you to read your manuals carefully. The manual for the mixer has a page with wiring diagrams for cables. Here is a link to a site with lots of good info and an invaluable FREE book that you can download:http://www.recordingreview.com/ I hope this helps.
Nov 11, 2010 | Behringer XENYX 2442FX Mixer
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Peavey PV6 Mixer Logo
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
