Question about Vehicle Parts & Accessories
Heat exchanger for peugeot 407 2005 - Vehicle Parts & Accessories
    Filmmaker:
    Uploaded 5 video answers.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
You should check at your Peugeot Car Dealership.
This should be your heat exchanger.
Original part code 6448 S7 or aftermarket hella 8FH 351 315-571, it should be around 200$. heat exchanger for peugeot 407 2005 - aa54c929-ee88-4847-935c-83a8563c2c73.png
Posted on Feb 18, 2014
My car is PEUGEOT 206 2004 1360cc ,When it speed slow down that happen engine shook .
How do you know the engine is doing this, it is more likely the brakes are causing this.
Jan 13, 2017 | Peugeot Cars & Trucks
Tip
Heat Air Exchanger for Heat Recovery
An air-to-air exchanger is used to recover heating or cooling and to improve the air quality of the building that it serves. Typically an air exchanger has two fans, one blowing air into the house and one blowing air out of the house. In the winter time the one fan brings the outdoor cool air through the core warming it with the warm stale air you are exhausting. In the summer time the warm air from the outside will be cooled as it enters through the core to save on your cooling.
Air exchangers often are used to perform many functions such as reducing air contamination, heating or cooling air entering the building, and humidifying or dehumidifying air before it enters the building. Air to air heat exchangers or heat recovery ventilators, are used to provide a balanced flow of air into and out of a building. Ultimately an air exchangers main function is to switch the stale inside air with fresh outside air while exchanging the heat or cool in the process.
There is some controversy about the savings of exchangers. Not only does it require electricity to run the air exchanger, but the air the exchanger brings into your house must be brought up to temperature. This may require that more electric is used to cool your building or that more fuel is also required for heating.
The amount of air that these air exchangers bring into a home may vary depending on how the system has been installed. The codes in many places require a minimum amount of air to be exchanged. Check with your codes official to see what the requirements are for you.
Air exchangers can be a very good thing for many buildings. Especially those that are very large and typically have a lot of occupants with little natural air exchange from doors or windows being opened. However they are also a health hazard if they are not serviced
All air heat exchangers will require regular maintenance. The problem is that this is almost never performed by homeowners, and unless they know about the exchanger it is often overlooked by contractors during service calls. The real problem is that clogged, air-to-air exchangers can make the indoor air significantly worse than it would be without the system installed at all. If you have a home that already has a heat air exchanger, make sure that you keep it very well maintained or disconnect it.
Many air exchangers are controlled simply by on and off switches, but in some applications where the removal of humidity is required, then a humidistat can be used to turn the machine on and off to achieve the humidity level that you want. In cases where there may be a lot of humidity the air exchanger may not be enough to solve the problem. Other devices may be needed to lower the humidity to the level that you want.
on Dec 24, 2009 | Heating & Cooling
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
How do heat exchangers work?
The heat exchanger is a thin metallic component of a fossil-fueled furnace whose purpose is to transfer heat from the gas or oil buning on one side of the sealed chamber to the air passing across and coming in contact with the other side of the sealed chamber. By 'sealed' I mean the burning gasses do not come in contact with the air that circulates within the living space.
Mar 11, 2015 | Heating & Cooling
Where is the heat exchange in a rheem pool heater located ?
The PVC plumbing is hooked into the front header, the front header is attached to the heat exchanger. The heat exchanger looks like copper finned tubes with a steel plate on each end. You need to disassemble heater working from top down to get to the exchanger. A skilled tech can replace an exchanger in under one hour service call.
Aug 19, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Leaking heat exchanger
balance chemicals in pool and replace heat exchange
Jan 08, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
014 code
A 14 code means the thermal fuse (white wire which wraps around the heat exchanger) has snapped. This occurs if the heat exchanger reaches a dangerously high temperature. To correct this error code you need to replace the thermal fuse and keep the heat exchanger from over heating. Typical reasons the heat exchanger over heats are:
1) scaling in the heat exchanger
2) combustion chamber dirty and burning hot
Oct 07, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
V-belt exchange on Peugeot 205 XL . I would like to know how to exchange the V-belt between alternator and engine belt pulley.
slacken off the bolts holding the alternator to the block,then push it towards the block,you will then be able to remove the belt and replace it.
lever the alternator away from the block to tighten belt(1/2 inch play on longest stretch)then do up the bolts and check free play again.DO NOT OVERTIGHTEN BELT.
Jun 01, 2010 | Peugeot Liberte Cars & Trucks
How can i exchange a peugeot 206 factory fitted radio with the same from another peugeot 206?
Just use the special keys and pull it to yourself. The terminals must be unplugged and then insert the new one. Before that, plugg terminals again. It's very simple operation.
Don't forget the new radio maybe ask for code. Try to get it when buy the new one...
Aug 27, 2009 | Car Audio & Video
How do i change 12v power / cigarette lighter! in a Peugoet 206
The cigarette lighter is connected to a harness that's being the unit. You need to most likely remove the panel that the cigarette lighter is attached to in order to remove the lighter unit out. Once the unit is out, disconnect the wiring harness to exchange it. I don't know how exactly your lighter will come out
Aug 25, 2009 | 1991 Peugeot 405
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
