Hi i have a logik tv e22/23b-gw-tcd with a shorted zener ZD503 and dont know the value the psw is PC40005-1CG do you know the value Please
4 Suggested Answers
  • 2318 Answers
SOURCE: AKAI MLT168A Power Supply
Here are the values for the parts:
R104 and R105 are 100 ohms 5% 1 watt but you can use 2 watts.
R107 is 200 ohms 5% 1 or 2 watts.
C17 is 2200pF 10% 1Kv.
Posted on Dec 06, 2008
SOURCE: I have a E22/13B-GW-TCD-UK logik
Typically you will not need a driver to use any monitor. Ensure that the monitor output of your computer is compatible with the video input of the television.
Posted on Mar 05, 2011
  • 20 Answers
SOURCE: Polaroid 860-AZ0-GF371H Power Supply Unit. After
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Posted on Aug 26, 2011
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
My Technika TV model X22/14C-GW-TCD-UK loses all of its channels when I turn it off. I have to retune everytime I turn the TV back on, Any Ideas welcome, many thanks
All sets use a eprom in some form or another that stores the memory of what up/down channels are programmed into the memory of the set-I will presume no box is used in line with this set for signal---very rare for this problem to even happen---next try when turn on to direct enter a known channel and see if set goes there--then manually add it in the menu---if set does not lose that memory at worst you can manually add every channel one at a time.
Oct 30, 2012 | Televison & Video
I have a E22/13B-GW-TCD-UK logik television that I want to use as a monitor for my computer. Do I need a driver?
Mar 05, 2011 | Televison & Video
Shorted zener diodes in primary, needs exact values!!
There should be a circuit designation printed on the board. Can you poat that here please? I should be able to get the part number from that. It will be CRxx or Dxx.
Thankis,
Dan
Jan 28, 2009 | Panasonic TC-29FJ20 TV
AKAI TV Repair Question
If Z3 was shorted, there are 2 surface mount resistors that were damaged when Z3 became shorted and they have to be replace as well. The reference designator for the resistors is R65A and R65B, their value is 10 ohms and 1206 is the body size of the resistors.
Jan 16, 2009 | Akai LCT2701TD Television
UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Jul 02, 2008 | Televison & Video
Tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
-GR
Jun 28, 2006 | Mitsubishi CS-35503 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
