Question about Kitchen Appliances - Others
Frutina slush machine
Should the machine slush just water? its been running 45 mins water is just cold?
  • 2,237 Answers
If the compressor is running and it's not freezing, it may have low refrigerant. need to have a professional recharge it. if the compressor is off, check the defrost timer (if your model has one) to see if it's on defrost.
Posted on Feb 26, 2014
Hi does anyone know anything about the frutina slush machine. Ive just bought a preowned one. Im not sure its working right and it didnt come with instructions. Thankyou
Well I live in Southampton, and Ice Frutina are based here. The liquids come in great big containers that you just pour in ready mixed I think (or perhaps its from concentrate, I'm not sure) but either way the mixing instructions should be on most slushie mix containers. For the machine to make slushie you basically need two things to happen...
1) the powerful refrigerator within the unit should function and chill/freeze the liquid in the hopper
2) The agitator should be constantly turning inside the hopper to break up the ice crystals as they form turning the liquid into slush rather than just a block of solid ice.
If the refrigeration is working, you should notice a pretty quick drop in temperature of the liquid in the hopper... It may be worth checking any fans are working properly and not seized up. Check the refrigerant compressor is humming.
That's about as much as I can help you I'm afraid. Hope it ends up working for you :)
Jan 07, 2017 | The Kitchen Appliances - Others
How long does the 55 degree normally run for
Depends on the water temp going into the machine. Dishwashers should be connected to cold water. Some people fit to hot water but the machine will go through the cycle too fast and you wont get a decent wash result. 55 isn't superhot for a machine (I assume this is 55 celcius?) Most machines will take about 45 mins to an hour.
Jan 03, 2015 | Dishwashers
I have a sunsip slush machine and is not freezing, and machne is running for nearly 6 hrs
if the mix is cold but not freezing, you may be low on refrigerant or the timer is in defrost (if it has that feature). if it's warm, either the solenoids are not opening or there is no refrigerant. check the exhaust. if there is little air flow, clean the condenser coils (air intake). if it's cold, the compressor is not functioning or no refrigerant. for low or no refrigerant, you have a leak. take it in for repair
Jul 21, 2014 | Kitchen Appliances - Others
My faby slush machine is freezing up
mix too lean. add a bit more base. also check the torque switch next to the stir motor. if it's stuck open, it won't stop freezing
Apr 02, 2014 | Faby Cab S.p.a Faby CAB Frozen Drink...
How to clean
empty the bowls, fill with cool water and flush. remove the top and the bowls. wash any residue on the bows with mild soapy water and a soft sponge. do not use a scotchbrite pad. same with the augers and the evaporator barrel. put food safe lubricant (i.e. superlube) on the shaft, the auger nose, and the spigot rings and reassemble.
Nov 10, 2013 | Kitchen Appliances - Others
Frutina slush machine what button dose what
Hi sorry i know this a old post. Im just wondering if you found out what the buttons do as i dont have an indtruction manual and need to know myself :)
Thanks
kate
Jun 19, 2013 | Kitchen Appliances - Others
In slush machines, how come the slush does not get completely frozen?
slush is made from sugar and water bonding together. the sugar is used as an antifreeze and then the mixture is constantly spun by the machine in order for it not to freeze.
Jan 24, 2013 | Kitchen Appliances - Others
I have an Ultra 2 bunn slush machine. One hopper
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Is there a water filter on the washing machine? We've had well problems and the water just trickles in taking 45 mins to fill. GE Adora top loader
There is a water inlet valve on the machine, for cold and hot water. These have screens on them, once they get to much sediment, they will restrict your water severely. These are located on the back of the machine, and they are what your water lines screw into.
Mar 29, 2010 | GE Washing Machines
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Kitchen Appliances - Others Logo
228 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
