Question about Sharper Image Robotic Zig Zag Zog Alien Toy
Zig zag zog sensors do not respond. Other lights flash and motors work but does not respond to anything in front of sensors.
What is the light "Sensing" means when flashing
its normal for the new washers to sense how or what type of load you put in it , first thing after start is pressed , if it stays in sense! then it has detected a fault , either the sensor or the load is at fault , try the manual setting and see what it does
Jan 10, 2015 | Watches
Luminux furnace won't kick on. Makes sound like its trying. All hoses are clear. Shows 3 lred lights flashing. 1. 2. 3. Any help would be greatly appreciated. Thx
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition providing current to flame sensor--main blower motor comes on after a set time
Feb 08, 2014 | Luminox Watches
How to shut off FLASH LT on g shock
Should be able to push light button again and it should go out
May 12, 2012 | Casio G-Shock GA-120A-7A GA-120A-7 Analog...
The buttons are not responding for my puma touch sensor 30 lap
You have to leave the light button pressed until you click there and beep and buttons work
Apr 19, 2012 | Puma Active Collection Fluctuation...
Buttons not responding
Hey, I bought one and it's the same, I don't know how to change the time or do anything with the watch, if you already know how to make it works please tell me .. thank you!
the_paper_girl@hotmail.com
Dec 21, 2009 | Puma Active Collection Fluctuation...
PRG120 button tone
Does the alarm work? if not, it is quite likely the battery is low. You can tape it up in a window to recharge the battery for a couple of days, direct sunlight is not necessary. Normally "Recovering" flashes. If the battery has been depleted for too long, it is possible the battery is now damaged and may need to be replaced.
As for settings, try pressing both buttons on the right side simultaneously in various modes, especially settings or alarm modes and see if that turns back on the beep. Perhaps press the upper left button for 5 seconds until various options start flashing, then try double right button presses and see what happens.
Hope one of these helps.
May 07, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Mar 10, 2008 | Timex 27191 Wristwatch
Sharper Image Robotic Zig Zag Zog Alien Toy Logo
32 people viewed this question
Top Sharper Image Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Sharper Image Watch Expert? Answer questions, earn points and help others
