Question about Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint Ultima WF860 Front Load Washer which makes a loud banging noise when it is spinning. Have you any ideas what could be wrong please?
Whilst the machine is in spin mode (especially 1600) there is a loud banging noise. I wondered if you could tell me if its the bearings or not.
    New Friend:
  • 46 Answers
You've been overloading the machine and using the wrong liquid laundry soap, Huh?! You're supposed to ALWAYS use the HE liquid laundry soap per manufacturer's instruction manual. Oh well, it keeps us tech's in business. So here is the problem. The washer basket has a shaft with a spoked hub called the spider & shaft. The shaft is made of steel, but the spider spoke that connects the basket to the shaft BY DESIGN is made of aluminum which corrodes in certain types of oxidizers such as laundry soap. The spider/ shaft is broken! Therefore, you shortened the life of your washer by not following directions and abusing the machine. It's a common ignorant act of incompetence. I mean relly how many people actually sit down and read their owner's manual? Or, it's oh! I forgot. Although, the truth is most probably you were being cheap on soap and overloading to save time, soap, water and electricity.
Having said all that... your washer if finished. The cost of repairs aren't worth the effort. It's better if you just call a used appliance recycler person such as myself and have them pick it up for a small fee. Go out and buy a new washer/ dryer set with a 1 year warranty and buy an additional 2 years warranty to protect yourself from expensive repairs later. After 2 years usege... sell them on craigslist as used appliances and gobuy new machines again using the money from the previous machines to offset the cost of new ones. That's the best advice you'll get from someone who has done the numbers. New Front Load washers and dryer have a short life by corporate design and new and improved mission statements.
Posted on Feb 08, 2014
  • jamezgregory
    jamezgregory Feb 08, 2014
    I have tried many ties to find a cheap way to repairfront load washers and the companies know they've got us. To repair a front load washer costs half as much as a new frontload washer, BUT there is NO warranty and NO guarantee it will last ! Best solutionis to buy a new set or revert to top load commercial quality washers and dryers.
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Posted on Jan 31, 2010
Testimonial: "Thanks for your help. In the end it was the front balance weight that had been gradually coming looser and looser and needed fixing pack into place."
SOURCE: Hotpoint ultima wf860
hi, i have the same machine..i have a feeling it does this annually to make you call an engineer. to reset it do this; hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesnt always work 1st time so keep trying, good luck x
Posted on Nov 14, 2006
SOURCE: Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Posted on Nov 14, 2008
SOURCE: Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Posted on Feb 17, 2009
  • 5 Answers
SOURCE: hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Posted on Sep 17, 2009
Hi, My washing machine drum appears to be loose. When the drum is turning slow it seems to go side to side as well as rotating. When the spin initially starts the drum seems to bang on the sides of the...
Sounds like worn drum bearing however check the top spring is not snapped.Remove lid you will see if spring is broken if not and suspect bearing its quite an expensive job,do you know Hotpint have a 5 year warranty on parts only call charge is around £105........Worthwhile considering as the parts would cost around this to buy excluding labour...Good luck
Jun 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Drum is not spinning, what could be wrong?
motor brushes worn, motor faulty, broken wires or faulty module. unplug b4 checking.
Apr 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
Noise when spinning
Remove drive belt and spin drum by hand, if it is noisy, or feels rough, then the main bearings have failed, if no noise, then check for noisy motor bearings.
Thanks.
Jul 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine
f05 is a drainage problem, ther may be something stuck in your pump.
its in the back of the machine in the corner. take the side hose off and unclip the pump from machine and look in to see the propellor may have foriegn object in.
Dec 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF840
all i can suggest with the info you have given, is to remove the lid and check for anything lose like the weight block etc also have you checked the inner drum for play, maybe the bearings have gone please not to all it is not safe to continue to run machines that are making noises, they can only get worse making more damage, what can start off as something silly can eventually write off the machine start with that and see how you go, glad to help, if i have helped please rate me
Oct 03, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
113 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
