Question about Dometic Rooftop RV Air Conditioner
I have a rooftop dometic roof top air conditioner it wont turn off changed batterys in remote still wont turn off ??
    Genius:
  • Dometic Master
  • 1,363 Answers
Thermostat, relay module issue.
Posted on Aug 18, 2015
SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
Posted on May 30, 2008
22yooper
  • 828 Answers
SOURCE: Dometic Rooftop RV Air Conditioner
Yes that does sound right.
Posted on Jul 11, 2008
  • 68 Answers
SOURCE: need to know how many amps the model # 57915.741 draws
Compressor amp draw is 7-8 amps
Posted on Mar 19, 2009
farfield
  • 462 Answers
SOURCE: My dometic RV rooftop air conditioner is leaking
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Posted on Jul 10, 2009
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
Where can I get a heater kit no. A70011 for a SL110RB dometic-aire roof-top air conditioner?
Any dealer should be able to order for you. Here's dometic site to locate nearest dealer to you.
https://www.edometic.com/allusr/srvctr.nsf/dl?OpenView
Aug 13, 2014 | Dometic Rooftop RV Air Conditioner
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
Noisy roof top airconditioner
pull shroud and isolate where noise coming from.
Feb 17, 2013 | Dometic Rooftop RV Air Conditioner
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Sep 01, 2010 | Dometic Rooftop RV Air Conditioner
How do find the roof rafters in a pop top.
Hi; Try using a electronic stud finder and switch to metal detection. Or maybe call or google the company that built the popup. Sometimes they can tell You exactly where to make Your cuts...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
Duo-them 15000 BTU roof air
Is this a non-ducted system with dials to turn on it, or is it controlled by a wall thermostat ?
Aug 20, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
124 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
