Question about Bauknecht Dishwashers
Bauknecht gsf 4851
Machine won't work. green 'shower" icon clincking. is something missing? or some other prob. thnx in advance
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: My Bauknecht GSF 6550 dishwasher
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. The error indication can be a short in the circuit, check the heater circuit and the pump motor.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Posted on Sep 03, 2011
Just bought a 98 jeep grand cherokee larado, has a clincking sound and won't start. does anyone know hwat the button under te battery is for?
the switch under the battery tray is a ambient temp sensor and it charges the battery accordingly to make sure it does not over charge or under charge if it goes bad your battery wont charge. Thats some info for you what it sounds like is a bad starter solenoid. if you re post i can help you more im a college student for a automotive high performance school and a big jeep person i got two
Jan 28, 2012 | 1998 Jeep Cherokee
My creda shower 8500dl won't shut off water keeps
Switch off the power at the main switchbox!
Unscrew the shower cover to reveal the main valve/switch assembly (green in my case)
On the green valve you can line up the bit that moves to select power settings and remove it
Undo the two screws holding the outer switch frame and lift it off
Undo the two screws holding the valve body in.
Remove the valve body, underneath you will find an ordinary tap washer - probably split
Replace the washer - I didnt have an exact match in my toolbox but drilled the middle out of a large tap washer to match
Reassemble..
Aug 10, 2011 | Home
Triton aquqtronic 4 plus shower showing low water pressure
Hi Rossouw hear
Most prob ur head is cloged up with ground ect. remove the shower head by turning it left , remove all the stuff that may have cloged it , it will be traped in a sif at the back of the head. clean nice and put back and all wil be working fine again.
plz rate my advice and let me know if u have more prob or this 1 is not resolved
Jun 20, 2010 | Home
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
FORMAT problem...im in BIG trouble..
you can format it once. . like that you formated.. I think you didn't formated properly.. If you can enter number plesae press *#7370#. This is another code for formating... otherwise made to restore factory settings...Your phone will be all right...If it is not coming in the sense update your phone software version from nokia. com...your phone will be good and speed also will get increased...
Dec 07, 2009 | Nokia 6600
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
CD/DVD drive letter missing. Happened before.
right click my computer, properties, hardware tab, click device manager, highlight computer icon, click action, then click scan for hardware devices, let it scan it should find, i hope this works please give me your feed back if this works ok.. thnx se ya, fixya.
Dec 12, 2008 | Acer (4432A-002) CD-RW Burner
Icon problems:(
Can you pls post a screen shot?
Jan 12, 2008 | Microsoft Windows Vista Ultimate Edition
Dishwashers Logo
29 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
