Question about MA Audio HK401SX Car Audio Amplifier
Best amplifier for two starsound subs 3500 watt dvc 2 ohm
3 Suggested Answers
  • 53 Answers
SOURCE: i have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Posted on Oct 19, 2009
  • 53 Answers
SOURCE: 2 alpine type r 15's 4 ohm dvc and 2 american bass
Option 1 (parallel) = 0.5 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono This set up will blow your mind as your amp will put out 1800rms at 0.5 ohm
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
Can it run at 2 ohm
Yes it will run at 2 ohms but each channel will run at 65 watts rms. So that would be 4x65 rms.
Mar 11, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
Just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
Hello bigmac208,
Yes, that would be the best connection for both the subs and the amp.
I'd wire the sub voice coils in series since the amp will not be stable at 2 ohms when the channels are bridged. The power will be somewhere between 100-200 watts RMS to each sub. While it's not pavement pounding, it should provide pretty good bass, especially if you tweak the crossover and boost settings for best bass response.
Hope this helps.
Aug 28, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
MA Audio HK401SX Car Audio Amplifier Logo
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
