Question about Yamaha RX-397 Natural Sound AM/FM Stereo Receiver, 100W
Yamaha memory problem WD292000 - Yamaha RX-397 Natural Sound AM/FM Stereo Receiver, 100W
Remove Memory guard on Yamaha HTR 5940
select memory guard and press the sideways cursor to select no. it should turn the lock off.
Oct 10, 2013 | Audio Players & Recorders
We are working with a yamaha HTR-6240. The memory guard is locked on and we wont to use auto setup. Also, as it is currently set, we are getting a lot of volume from our rear speakers and very little...
The manual is available at retrevo.com
Page 43:
Under Setup / Memory Guard on/off
For volume of individual speakers see Speaker Setup (Auto) or (Manual) on page 39.
Dec 23, 2010 | Yamaha Audio Players & Recorders
2002 yamaha venture radio tripmeter memory circuit,need wiring diagram.lost radio/tripmeter memory when batt. was replaced.
There is a fuse labelled Backup which powers the memory for the audio setting, trip meters when the key is off....make sure the fuse is intact.
Apr 02, 2010 | 2002 Yamaha Royal Star Venture
Can the ecu memory be flashed on a yamaha EF2800iportable generator? My 2800i will start and run for about 90 seconds and then shuts down. Carb is fine. Two issues: 1. It is not generating...
It sounds like its running on the gas in the carburetor and not the gas filling back up to run more, I bet you have a gas supply problem to the carburetor! Try Babbitts Yamaha Partshouse online...
Mar 12, 2017 | Yamaha 1,000 Watt Portable Generator...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
I have a clavinova CVP 409. If I try to record using an external memory device (external Hard drive or memory stick, a message appears; DISC ERROR. Can you please help me solve the problem or direct me...
I SUSPECT that the CVP 409 will ONLY talk to the Yamaha USB floppy drive, not a hard drive or memory stick.
The internal drivers for these musical instruments do not have the "smarts" to talk to the wide variety of peripherals that PC's are able to.
Sep 10, 2009 | Yamaha Full-Size Keyboard
How do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Aug 28, 2009 | Yamaha Computers & Internet
My yamaha dvd-s661 has usb connection but won't play the audio
Make sure in the setup of the DVD player that every type of audio is downconverted to 2 channel plain old analog stereo.
Mar 05, 2009 | Yamaha DVDS661 Player
Memory guard on
Hi Rocco
I too have searched the user manual on this unit, and have not found any reference to "memory guard". Can you give me more information about the feature you are trying to operate and I will try to assist you further
Here is a link to a PDF version of the manual for free. Just enter an email address and there you go.
regards
Graeme
Feb 16, 2008 | Yamaha RX-V596 Receiver
Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Nov 29, 2007 | Yamaha RX-V1000 Receiver
Yamaha RX-397 Natural Sound AM/FM Stereo Receiver, 100W Logo
50 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
