My sony SA-VA3A system model #803397 speakers do not come on when you press power button the power cord seems to be working I tried plugging tv cord in bottom of speaker plug in and plugging tower plug in to wall and tv still works so isthere A power amp in side left speaker if so not working or is it in the speaker cable connections?
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
  • 231 Answers
SOURCE: Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Posted on Dec 24, 2007
  • 7 Answers
SOURCE: blown internal sony tv speakers
in menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Posted on Jan 26, 2008
SOURCE: unlock apex tv model # AT2702
i need to unlock my tv
Posted on Dec 05, 2008
gtaplytmpt
  • 90 Answers
SOURCE: speaker hookup on back of tv
I looked up the specs on your TV and Toshiba says that all of the A/V jacks on it are inputs. It doesn't list any outputs for external speakers other than the Coax digital output jack for surround sound systems. This would explain why you don't get any sound. The website where I got this information is as follows...
http://www.tacp.toshiba.com/televisions/product.asp?model=mw24fp1
Sorry for the bad news.
Posted on Jan 02, 2009
I have a sony sa-va3a sorround 1993 model I trey to connect my rear speakers on system to reciever didnt work .my front speakers work on system but my rear speakers dont Can replacing fuse help? an where...
Fuses are not your issue. Look in your owner's manual. Find the procedure to return your unit to "Factory Defaults". I'm sure you just have something switched wrong.
Oct 02, 2013 | Audio Players & Recorders
My sony mhc lx10000 has no audio whenever the display reads speakers B ...HOW DO I RESET IT TO PLAY?
This is for model # MHC-LX10000. All of these answers are WRONG ! Do not listen to these. Its very simple, I had the same problem happen to me today and simply reset the system to the original factory settings. Here's how to do this and is very easy. It is mentioned in the user manual on Page 32. First unplug the power cord. Then plug it back in and turn on the system with the power button on the audio system. At the same time, press 3 buttons - the square/stop, ENTER and the Power buttons. The system gets reset to factory settings and the Speaker B will disappear. You will lose all your presets but the speakers will work once again. What a relief it was to me ! You can then set up your presets again. I wonder why with all these system support techs available here and bragging about how many years they have worked for Sony, none of them could mention this simple solution.
Sep 10, 2012 | Sony MHC-LX1000 Shelf System
Need manual for sony SA-WMS230
the Sony SA-WM 230 MICRO SATELLITE SYSTEM is also known as Sony SA-VE230. Follow up link for service manual:
http://www.go-gddq.com/upload/2010-04/10041211301999.pdf
Feb 02, 2012 | Sony Audio Players & Recorders
I have a sony sub model sa-wm20 will it work with this mini system
Read the manual.
http://www.retrevo.com/support/Sony-SA-WM20-Subwoofers-manual/id/752ag408/t/2/
You would use the Speaker Terminal hookup option. Your front speakers would attach to the sub's speaker terminals.
May 02, 2011 | Sony MHC-881 Shelf System
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
I need the System Control Cable for my Sony SA-VA100 Speakers!
Need the System Control Cable to a Sony Sa-VA100
Jun 22, 2009 | Sony SA-VA100 System
Sony SA-VA 100 won't turn on
You can try a factory reset.
Push and hold down Dolby NR, stop and disc 7 buttons, then push power.
Otherwise it looks like $60 to $100 repair bill. These are not the most repair freindly units.
Good Luck.
Mar 08, 2009 | Sony SA-VA100 System
Sony SA-VA10
Hi, Have you been able to locate the cable for your Sony speaker system? Thats a shame that they would take just the cable. Anyways, I have the sa-va10 model just like you. I just upgraded to a new sound system. And I have the cable. Tho, I m sure somewhere on the net, like ebay, amazon or even Sony should be able to help you. I would call them. Those speakers are not that old, and maybe Sony still has a ton of those cables in stock. Esp. since the system is only around 14 years old. Relatively thats still pretty new.
Jan 02, 2009 | Sony SA-VA10 System
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
