Question about Malber Washing Machines
Malber p505 guide
I need a Malber p505 guide. I simply do not find how to work on this. regards
  • 1294 Answers
SOURCE: MALBER WD 800
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 04, 2008
  • 55 Answers
SOURCE: MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
Posted on May 06, 2008
CMV9
  • 594 Answers
SOURCE: Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Posted on Aug 14, 2008
  • 29 Answers
SOURCE: Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: looking for booklet on how it works
Try MalberUSA, they import the machines and should be able to put you in touch with a supply company if they do not have a manual on hand:
61 Commercial Avenue
Garden City, NY 11530-6417
(516) 294-6660
Posted on Apr 03, 2010
Spin cycle not working on Malber washing machine, it is on a used boat we just bought and it is in Fort Lauderdale but coming to NY soon, boat broker says he cant locate a person to fix the Malber- an
In New York, call Malber Distribution Corp at 516-323-5299.
They can schedule a technician to fix your machine. They've been fixing Malbers for about 25 years.
Tell them Mike, in Wash DC, says hi.
Mar 06, 2014 | Malber WD1000 Front Load Washer/Dryer
Hi Folks, I have just realized why my Malber needed repairs after I first moved it seven years ago; I didn't have the transit spacers when I bought it second hand from a Polish couple. I have just moved...
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in local telephone directories OR stay on line and search for 'malber washer service' for instance or 'malber washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 16, 2011 | Malber WD1000 Front Load Washer/Dryer
Need manual
Unfortunately, this manual is not available online. I emailed Malber regarding the manual. Although they do not have an online version, they indicated that they would mail a hard copy of the manual to your home. Call 800-387-2011 Malber will be glad to send you the manual.
Feb 08, 2011 | Malber WD2000 Front Load Washer / Dryer
MALBER WD 800 Features
I have a manual if you wold like a copy.. I can fax it to you
Heartcracker6@yahoo.com
Mar 31, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Malber Company - Italy. Address
need to find a manual for Malber WD8008
Oct 25, 2008 | Malber TD700 Electric Dryer
May 02, 2008 | Washing Machines
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Solve problem to use malber washing machine &dryer
Contact Malber USA (info@malberusa.com) and they can sell you a new manual.
Oct 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
71 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
