Power Issue My sony SA-VA3A system model #803397 speakers do not come on when you press power button the power cord seems to be working I tried plugging tv cord in bottom of speaker plug in and plugging tower plug in to wall and tv still works so isthere A power amp in side left speaker if so not working or is it in the speaker cable connections?
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
SOURCE: Samsung Flat screen 100hz tv - no power
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
Posted on Aug 11, 2008
SOURCE: speakers won't turn on
Have you checked the fuse in your plug. If the fuse has blown it won't work in any wall socket. Change the fuse for a new one anyway, then try again.
Posted on Sep 30, 2008
SOURCE: No Power
This is a very common problem. Theres a guy on ebay that will fix it for you for 24 bucks plus 5 bucks shipping. When you open the monitor, on the back panel there are 2 boards. One is a power supply board, the other is the interlogic board. The power supply board is where the problem is. I do not know the exact component that needs replacing as I did not test this yet. I do not have the proper test equipment. For 24 bucks, I'm just gonna let the ebay guy repair it. I will report my results here when I get the board back. I'm also gonna mark the components so I know what they replaced.
Posted on Oct 24, 2008
  • 3 Answers
SOURCE: magnavox mwc24t5b
The power supply is shutting down for one reason or another. This unit has 4 shutdown alarms feeding the main processor. It doesn't take much to trip it and believe me, it's a ***** to find it if it is a subtle condition. The VCR could be shutting it down as well if it is not reset exactly right.
This is what I did with the one unit I worked on; It would shut down after 5 seconds. The picture was good when it breifly came on -- but it shut down anyway.
IC1601 is the shutdown opto isolator that will shut off the supply. I removed it and the set came on. After a few minutes one of the power supply diodes started smoking so I unplugged it. The diode, D1618 was bad so I replaced it and the TV worked. But, I could not put IC1601 back in without it still shutting down. I spent hours searching and couldn't find anything. Since it was my son's TV (which he found at the dump) it was OK by me. BUT, if you remove this IC, (it is a four pin located near the yellow transformer) the set will come on no matter what. Just remember, if there is a problem, it will show up quickly. Maybe a new troubleshooting method? Ohms law troubleshooting? No, unfortunately not. Just be careful and try to find the problem.
If you google this model number, you will find a free schematic that --someone-- uploaded to a free schematic website.
Posted on Nov 08, 2008
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
I have a sony sa-va3a sorround 1993 model I trey to connect my rear speakers on system to reciever didnt work .my front speakers work on system but my rear speakers dont Can replacing fuse help? an where...
Fuses are not your issue. Look in your owner's manual. Find the procedure to return your unit to "Factory Defaults". I'm sure you just have something switched wrong.
Oct 02, 2013 | Audio Players & Recorders
I have a Sony Surround Sound Bar model # SA-WCT100 that I owned for about a 2 yrs and it says push power detector. What does this mean and how can I fix this problem? This should not be happening on...
Message 2 of 31 (233,090 Views)
Re: what is push power protector message on sony bravia theatre all about and how to get the unit to [ Edited ] Options ‎11-26-2012 07:15 PM - last edited on ‎07-17-2013 10:20 AM by AmandaM
Welcome to the Sony Community.
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
https://us.en.kb.sony.com/app/answers/detail/a_id/39107/c/65%2C66/kw/39107
Thank you for your post.
May 26, 2017 | Sony Audio Players & Recorders
Panasonic Home T, sa-pt760, message LOCKED
While the unit is on, press and hold the play button and the power button, display should say unlocked. If this doesn't work, try it using the stop button and power button.
Apr 03, 2013 | Panasonic Audio Players & Recorders
My sony mhc lx10000 has no audio whenever the display reads speakers B ...HOW DO I RESET IT TO PLAY?
This is for model # MHC-LX10000. All of these answers are WRONG ! Do not listen to these. Its very simple, I had the same problem happen to me today and simply reset the system to the original factory settings. Here's how to do this and is very easy. It is mentioned in the user manual on Page 32. First unplug the power cord. Then plug it back in and turn on the system with the power button on the audio system. At the same time, press 3 buttons - the square/stop, ENTER and the Power buttons. The system gets reset to factory settings and the Speaker B will disappear. You will lose all your presets but the speakers will work once again. What a relief it was to me ! You can then set up your presets again. I wonder why with all these system support techs available here and bragging about how many years they have worked for Sony, none of them could mention this simple solution.
Sep 10, 2012 | Sony MHC-LX1000 Shelf System
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
Sony SA-VA 100 won't turn on
You can try a factory reset.
Push and hold down Dolby NR, stop and disc 7 buttons, then push power.
Otherwise it looks like $60 to $100 repair bill. These are not the most repair freindly units.
Good Luck.
Mar 08, 2009 | Sony SA-VA100 System
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
