Sony SA-VA3A My sony SA-VA3A system model #803397 speakers do not come on when you press power button the power cord seems to be working I tried plugging tv cord in bottom of speaker plug in and plugging tower plug in to wall and tv still works so isthere A power amp in side left speaker if so not working or is it in the speaker cable connections?
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
  • 7 Answers
SOURCE: blown internal sony tv speakers
in menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Posted on Jan 26, 2008
  • 3 Answers
SOURCE: magnavox mwc24t5b
The power supply is shutting down for one reason or another. This unit has 4 shutdown alarms feeding the main processor. It doesn't take much to trip it and believe me, it's a ***** to find it if it is a subtle condition. The VCR could be shutting it down as well if it is not reset exactly right.
This is what I did with the one unit I worked on; It would shut down after 5 seconds. The picture was good when it breifly came on -- but it shut down anyway.
IC1601 is the shutdown opto isolator that will shut off the supply. I removed it and the set came on. After a few minutes one of the power supply diodes started smoking so I unplugged it. The diode, D1618 was bad so I replaced it and the TV worked. But, I could not put IC1601 back in without it still shutting down. I spent hours searching and couldn't find anything. Since it was my son's TV (which he found at the dump) it was OK by me. BUT, if you remove this IC, (it is a four pin located near the yellow transformer) the set will come on no matter what. Just remember, if there is a problem, it will show up quickly. Maybe a new troubleshooting method? Ohms law troubleshooting? No, unfortunately not. Just be careful and try to find the problem.
If you google this model number, you will find a free schematic that --someone-- uploaded to a free schematic website.
Posted on Nov 08, 2008
SOURCE: unlock apex tv model # AT2702
i need to unlock my tv
Posted on Dec 05, 2008
gtaplytmpt
  • 90 Answers
SOURCE: speaker hookup on back of tv
I looked up the specs on your TV and Toshiba says that all of the A/V jacks on it are inputs. It doesn't list any outputs for external speakers other than the Coax digital output jack for surround sound systems. This would explain why you don't get any sound. The website where I got this information is as follows...
http://www.tacp.toshiba.com/televisions/product.asp?model=mw24fp1
Sorry for the bad news.
Posted on Jan 02, 2009
I have a sony sa-va3a sorround 1993 model I trey to connect my rear speakers on system to reciever didnt work .my front speakers work on system but my rear speakers dont Can replacing fuse help? an where...
Fuses are not your issue. Look in your owner's manual. Find the procedure to return your unit to "Factory Defaults". I'm sure you just have something switched wrong.
Oct 02, 2013 | Audio Players & Recorders
I have a Sony Surround Sound Bar model # SA-WCT100 that I owned for about a 2 yrs and it says push power detector. What does this mean and how can I fix this problem? This should not be happening on...
Message 2 of 31 (233,090 Views)
Re: what is push power protector message on sony bravia theatre all about and how to get the unit to [ Edited ] Options ‎11-26-2012 07:15 PM - last edited on ‎07-17-2013 10:20 AM by AmandaM
Welcome to the Sony Community.
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
https://us.en.kb.sony.com/app/answers/detail/a_id/39107/c/65%2C66/kw/39107
Thank you for your post.
May 26, 2017 | Sony Audio Players & Recorders
My sony mhc lx10000 has no audio whenever the display reads speakers B ...HOW DO I RESET IT TO PLAY?
This is for model # MHC-LX10000. All of these answers are WRONG ! Do not listen to these. Its very simple, I had the same problem happen to me today and simply reset the system to the original factory settings. Here's how to do this and is very easy. It is mentioned in the user manual on Page 32. First unplug the power cord. Then plug it back in and turn on the system with the power button on the audio system. At the same time, press 3 buttons - the square/stop, ENTER and the Power buttons. The system gets reset to factory settings and the Speaker B will disappear. You will lose all your presets but the speakers will work once again. What a relief it was to me ! You can then set up your presets again. I wonder why with all these system support techs available here and bragging about how many years they have worked for Sony, none of them could mention this simple solution.
Sep 10, 2012 | Sony MHC-LX1000 Shelf System
I have a Sony SA-VE815ED SYSTEM. I have not used it in ten years. Can I hook it up to a HD TV?? Do I need a receiver?? How do I use the HDMI connections on video games, TV, etc?
The SA-VE815ED is a set of speakers. You'll need an receiver (with an amplifier either built in or separate) to connect the speakers to the TV. Depending on the receiver, you may be able to connect the HDMI cables from any set top box to the receiver and then have an HDMI out cable to the TV. (In this configuration, the TV speakers will not get the audio track. So you will want to ensure that the TV's speakers are off and the receiver is on when you play games.)
Alternatively, plug the HDMI cables directly into the TV and then connect the TV's audio out to the receiver. (Depending on the TV, your may need to get a receiver with digital audio inputs.)
Retrevo has the manual for the SA-VE815ED here: http://www.retrevo.com/support/Sony-SA-VE815ED-Speaker-Systems-manual/id/23108ci362/t/2/ . You'll need to enter a code to download the PDF.
I hope this helps.
Jul 22, 2012 | Sony SA-VE815ED 5.1 Home Theater Speaker...
My Panasonic sa-ak770 will not come out of standby mode
Check to make sure there are no shorts in the speaker wiring, if okay remove speaker wires from back, press power if it comes out of standby the wires or speakers are the problem, if there is no change the protection circuit is not functioning or the audio output ic's have a short.
Jun 09, 2012 | Panasonic Audio Players & Recorders
I have a sony sub model sa-wm20 will it work with this mini system
Read the manual.
http://www.retrevo.com/support/Sony-SA-WM20-Subwoofers-manual/id/752ag408/t/2/
You would use the Speaker Terminal hookup option. Your front speakers would attach to the sub's speaker terminals.
May 02, 2011 | Sony MHC-881 Shelf System
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
