Salom ssu-s0130 search for psu replacement
Comment on the effectiness of the title 'Stolen Rivers'
Has some pop, but how do you "steal" a river?
By rechanneling its flow so it runs elsewhere? It's a little too complicated, needs some 'splainin'.
Mar 06, 2017 | Miscellaneous
How to open sentry safe s0130 after being moved
Spray the key hole with graphite. Should loosen up whatever is stuck.
Jul 20, 2014 | Sentry Fireproof Safe
Serial video cable driver for linux
Hey Anonymous! Unfortunately, the SSU-100 Single RS-232 Serial Adapter is only 'officially' supported on the following Operating Systems:
Windows 2000, Windows XP, Windows Vista, Windows 2003
To the best of my knowledge, there is not a Linux porting of the drivers.However there is a Linux driver package for the Quatech ESU2-100 (see below)
http://www.quatech.com/ManualsDriversFirmware/Communication/serqt_usb2_2.6_1.00.tar.gz
I doubt they are interchangable.
May 24, 2014 | Quatech SSU-100 Serial Adapter
What are power supply specs for hp Slimline s5200z
HP say only that the psu is rated at 220W
(http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01911671&lc=en&jumpid=reg_r1002_usen_c-001_title_r0002#N121)
I
I rather think the specs are the same as this one and that themodel number is the model in yours
http://www.ebay.co.uk/itm/HP-Pavilion-SlimLine-s5000-220W-PSU-Power-Supply-HP-P-N-504965-001-PC8044-/221182783648
HP Pavilion SlimLine s5000 220W PSU Power Supply HP P/N: 504965-001 taken from computer when hard drive died in full working order has been cleaned ready to be reinstalled Model:PC8044 HP P/N:504965-001 AC INPUT:100-240V, 50/60HZ, 6A DC OUTPUT: +3.3V 16A +5.08V 15A TOTAL110W MAX +12.0V 16A TOTAL210W MAX -12.0V 0.3A +5.08Vsb 2.0A
However to certain take the panel off yours and have a look at yours
The are plenty of higher power replacements available search the internet for eg "what psu is in a hp s5200z"
20.December.2014
May 20, 2014 | HP Computers & Internet
Hi,I dont have any catalogues in my app manager and when i open my app manager this error is shown"operation failed".I flashed my mobile 4 times but ..... please help me
1. Make sure you have an active internet connection before updating the catalogs.
2. Go to Menu (top left icon on your desktop) -> "Application Manager", tap on top of the screen to open "Application Catalogs"; make sure you have the desired catalog(s) enabled.
3. If no catalogs are displayed, you may add them manually
Application Catalogs -> New
Catalog name: Nokia Applications
Web address: https://downloads.maemo.nokia.com/fremantle/ssu/apps/
Distribution: ./
Components:
-> Save
Catalog name: Nokia System Software Updates
Web address: https://downloads.maemo.nokia.com/fremantle/ssu/mr0/
Distribution: ./
Components:
-> Save
Catalog name: Extras
Web address: http://repository.maemo.org/extras/
Distribution: fremantle-1.3
Components: free non-free
-> Save
-> Update
Mar 04, 2011 | Nokia N900 Smartphone
My 1f82-51 thermostat has no display so heat nor air is working
Change the battery if the thermostar has them. If not then the 24 volt circuit may not be working from the furnace. Does the furnace have 110 volts to it. Are the breakers all on.. Is the SSU at the furnace turned On if it has one or is the fuse in the SSU OK. If all of this is OK then try a quick test. Take the Thermostat off of the subase and put a jumper wire from R to G if the blower comes ON then the thermostat may need to be replaced...... This process will work for any type of thermostat that is acting up... Hope this helps
Jan 31, 2011 | Heating & Cooling
Want instuction manual for jane slalom pro pushchair
hi I have just brought a jane salome pro and cant seem to get the wheel to unlock to move to a 360 turn can anyone tell me how todo this please .. any info would be a great help many thanks
Jan 26, 2011 | Baby Gear
Usb2.0 to rs232
Quite often these do not need drivers and may just show up in your hardware list as an extra com port. The may also be listed in your usb hardware list.
But if that is not the case with you then here it is
Aug 24, 2009 | Quatech SSU-100 Serial Adapter
I need a model:SSU-S0061(SSU-S0061-1B) I.T.E Power Supply For my tv to have power and work.
Hello, I come from Shenzhen, China, I have you need the power of this model(SSU-S0061-1B). Please contact me. MSN:ttxiangtao@hotmail.com
Apr 23, 2009 | SVA-USA VR-30W 30 in. LCD Television
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
