Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Imaging unit soft switch - Konica Minolta bizhub C250 All-In-One Laser Printer
Minolta biz c203 error code c2451
Posted on Feb 26, 2014
I have bizhub c450 , printing time devoloper comin on edge of paper , my imaging units are nes
Removed all imaging unit then below you will see PCL in every imaging unit you must clean it with soft cloth completely. When PCL is covered with dust,toner,dev etc.. the developer from your imaging unit become to fall causing developer on edge of paper(dirty copies).
Dec 26, 2014 | Konica Minolta bizhub C450P Laser Printer
Ineo +200 status p 6 and p 21
P-6 : Cyan imaging unit failure
P - 7:Magenta imaging failure
P -8 :Yellow imaging unit failure
P -9:Black imaging unit failure
Select Imaging Process adjustment - D Max Density and if the setting value is negative readjust.
Check the drive transmission portion of the imaging unit and correct as necessary,clean theIDC registration sensor windows if dirty,clean the contact of the imaging unit connector if dirty,check the high voltage connector for proper connection.If necessary change the image unit or the image transfer belt unit.
P -21 : Color shift test pattern failure.
Wipe clean the surface of the transfer belt with a soft cloth or change the image transfer belt unit if the transfer belt is damaged.
Feb 21, 2013 | Konica Minolta Office Equipment & Supplies
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 error of c250
4 Change PRCB.
How to clean LED on bizhub c350
Clean the frame of your LED TV with a soft, clean, lint free, dry cloth. To clean the screen, first try wiping gently with the soft, clean, lint free, dry cloth. If that does not work, spray ScreenClean or another screen cleaner solution onto the cloth. Never spray it directly onto your TV screen. House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Jun 15, 2012 | Minolta C350 Printer
Hi, just wanting to know how to clean an imaging unit on a Kyocera FS-1920
open 2 screws at the top cover remove the cover take a soft wipe comes with the unit or any soft clothe and wipe gentle
Jul 21, 2011 | Kyocera Mita FS-1920 Laser Printer
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
May 14, 2009 | Xerox Phaser 7750DN Laser Printer
No picture
turn hard switch off in the back of the unit. Then put your finger on the soft switch on the front of the unit. While keeping your finger on the soft button in front, switch the hard button in the back to the on position and keep finger on the soft button for 10 secs, this will reset your vid settings.
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Spots on page
Clean out the toner spillage as best as you can. Your not supposed to use one, but a vacuum is the best method to suck it up. Once clean, replace the image drum (photoconductor unit). Also make sure the laser lens glass panel is clean - wipe it with a soft cloth or tissue.
Oct 02, 2007 | Brother HL-2040 Laser Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
73 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
