Question about Philips HR1861 700 Watts Juicer
Stopped working - Philips HR1861 700 Watts Juicer
Juicer stopped working
It sounds like a warranty issue if you bought it new. I checked the internet and this seems to be a budget juicer. I had the Jack La Lane model and fortunately the base unit (motor) was replaceable, however I concluded it was such because it wasn't heavy duty and they made money off it failing after a year. These are my personal feelings that you should look at a better model and of course you will pay more for the quality.
Mar 20, 2014 | Hamilton Beach 67800 HealthSmart Juice...
A small slice of cabbage got stuck at the bottom of the funnel where the vegetable goes onto the blade. The motor stopped immediately and is now not working. This same mishap happened about a year ago...
A small piece of cabbage should not stop this machine. If it did stop, look for the red reset
button on the bottom of the juicer. I've been using mine for 21 years and occasionally it will
stop when run for an extended period especially if vibration is present. In each case I waited
a few minutes and pushed in the reset button.
Mar 29, 2011 | Acme 6001 Juice Extractor
My motor just suddenly stopped working.
what happens if a screw peg breaks/cracks? Because; my motor suddenly stopped
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
Jun 29, 2010 | Omega 1000 Juice Extractor
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Fuse may be blown. Take off bottom, it is soldered to the circuit board. Unsolder and replace (I use a fuse holder) to make it easier
May 07, 2007 | Breville JE95XL Juicer
Philips HR1861 700 Watts Juicer Logo
22 people viewed this question
Top Philips Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Philips Juicer Expert? Answer questions, earn points and help others
